Results 1 to 4 of 4
Thread: How do I figure out the size of this nut?
    Mar 2004
    Seriously, as simple as it sounds, I just need to find a nut to put on the end of a ballscrew, and I don't have a metric thread gauge, so I figured I'd measure. Pitch is definitely 1.5mm, and measuring the major diameter with a caliper gives me 20.2mm. So is it M21 x 1.5? or M22? Or...??? Is there some standard (percentage) for which the major diameters are cut down to, relative to the specified size?
    This wikipedia page lists M20 and M22 as having 1.5mm pitches -- is this across the board? Or is it possible that someone makes larger nuts with 1.5mm pitch? I doubt that list is complete because I've seen M21 nuts.
    I don't want to have to order different sizes (especially since I'll probably have to buy a pack of 10 or more), just to get one single nut.
    Anyone know for sure how to figure this out?
    Cheers,
    -Neil.
    Registered Mitsui Seiki's Avatar
    Feb 2007
    20.2mm?
    It has to be M20x1.5.
    M22 has a major Dia. of 22mm and M21 doesn't excist.
    You can get a nut up M80 with 1.5 pitch.
    Stefan Vendin
    Registered Konrad's Avatar
    Oct 2003
    Edmonton Canada
    Could it be a 13/16" OD, 1/16 pitch?
    Konrad
    Mar 2004
    I thought that if I measured 20.2mm it would've been bigger. I dug through the yellow pages and found a local supplier who carried metric nuts and it turned out to be an M20 x 1.5. I figured it would've been more clear-cut to figure out the nut size based on a couple measurements.
    Thanks,
    -Neil.
  1. trying to figure out what i want.
    By smooth72 in forum Smithy
    Last Post: 08-25-2009, 01:26 PM
  2. How hard is it to figure out the size of cap and bridge rectifier for a power supply
    By journeyonline in forum General Electronics Discussion
    Last Post: 04-04-2007, 05:31 PM
  3. Help me figure my transformer size
    By scheek in forum General Electronics Discussion
    Last Post: 03-09-2006, 06:57 PM
  4. How to figure needed stepper motor size?
    By Hack in forum General Electronics Discussion
    Last Post: 07-19-2004, 04:43 PM
  5. How to figure out what servo size you need
    By replicapro in forum Servo Motors and Drives
    Last Post: 06-24-2004, 06:45 AM
