Old 12-15-2008, 09:38 PM
toolclaw is on a distinguished road
bridgeport cnc
I have this bridgeport cnc series 1 r2c3 with a heidenhain tnc 145 control and suddenly on the z axis it is showing gross positioning error. Heidenhain doesn't support this control anymore, and I have this guy that thinks he can fix it, but without the skimatics there is no way. Any suggestions?
Old 12-15-2008, 10:59 PM
Jukka Honkanen is on a distinguished road
is not coming from the control.
It could come from mechanics, motor, drive, cables etc.
The control only shows that your Z-axis is not following the control.
Can you describe the error more?
Jukka
Old 12-16-2008, 06:38 PM
CDISMACER is on a distinguished road
Smile Heidenhain Repairs
Hi.. CDISMACER Here.. take a look at this websites, My local (Chicago) Heidenhain rep says if it can be fixed, these are the guys.. http://www.clarksonco.com/
Good luck... Steve
Old 12-16-2008, 10:23 PM
Jukka
I have changed the x axis and the z axis around since they are the same, and the same thing happened. However after it shows the gross positioning error and it got cleared, the screen on the z keeps running, going higher and higher as though it is getting a signal.
Newbie- Bridgeport VMC 760 22 mak0 General CNC (Mill and Lathe) Control Software (NC) 12 11-10-2008 05:22 PM
Bridgeport Needs Air? JQ_Quint Bridgeport and Hardinge Mills 4 10-25-2008 03:46 AM
Bridgeport BTC 1 Builder Bridgeport and Hardinge Mills 24 05-17-2008 11:40 AM
which bridgeport james12s Bridgeport and Hardinge Mills 5 06-21-2007 08:29 PM
Bridgeport Value? smird Bridgeport and Hardinge Mills 20 06-07-2005 11:56 PM
