Old 12-13-2008, 05:54 AM
donl517 is on a distinguished road
Leveling a Lagun Vertical Mill
I've got a couple FTV-2S vertical mills that I need to level. I haven't done this in years but it seems to me we made a plate with a tapped hole and a lip (to keep it from rotating) to catch the edge of the machine. Then we used threaded rod as a jack screw to level them with a nut and washer on top to lock it in place. Does that sound right?
Any better suggestions, other than the $100.00 a set wedges?
Thanks,
Don
Old 12-13-2008, 09:00 AM
One of Many is on a distinguished road
For a typical knee mill it is not that critical. With a gaged variety of 4x4inch square pieces of sheetmetal, shimming the corners does the job just fine. As long as it doesn't rock, true level shouldn't be a problem.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 12-14-2008, 12:41 PM
EvanVH is on a distinguished road
Sheet metal shims work great. I like a machine level it just takes one more variable out.
Sometimes I need to use a level for a quick setup. If the machine is not level the set up will take a little longer.
Evan
Lagun mill powered knee jjclear Knee Vertical Mills 3 12-03-2008 01:29 PM
Go-Well vertical mill Matt130 Benchtop Machines 0 08-14-2008 02:09 PM
Lagun Mill (BP clone) CNC conversion How To? Kerry Harrison Bridgeport and Hardinge Mills 16 08-24-2007 12:23 PM
Lagun Mill (BP clone) CNC conversion How To? Kerry Harrison Stepper Motors and Drives 0 08-20-2007 07:31 PM
Best Vertical Mill? bvandenb Haas Mills 11 04-20-2005 05:47 AM
