Old 12-12-2008, 10:23 PM
seanreit is on a distinguished road
Is there a way to feed an offset in manually in Gcode
Say I have Z come to a position G0 z1.0
and I want it to automatically change it's postion on the next line to be 1.5 as in 1.0 is NOW 1.5.
Is there a way to do that?
I am facing a part and want the face of the part to be the new paramater without having to reset a distance manually in the mach 3.
Does this make sense? I hope it does.
Old 12-12-2008, 10:49 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
G52 ?
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 12-12-2008, 11:47 PM
So what would you put? G52 Z1.5
And continue with the program?
Old 12-13-2008, 12:13 AM
chazmtu is on a distinguished road
Try this "G92 Z1.5". It should change your Z position. Use G92.1 to erase it.
Chuck
http://chuckscnc.blogspot.com/
Old 12-13-2008, 11:16 AM
dertsap's Avatar
Gold Member
yes
if you want to shift 1" then its g52z1. , to cancel the shift use g52z0
it works for xyz and is quite handy once you get used to using it
Old 12-13-2008, 04:45 PM
Is there a way to do that?..
You use G0 Z1.0 to go to 1.0; why not use G0 Z1.5 to go to 1.5?
Old 12-13-2008, 09:30 PM
I think he wants to create an offset so the Z coordinate changes without moving the tool.
Newbie- cnc - is edge finding done manually? Numb Nut Benchtop Machines 16 11-09-2008 03:00 PM
can this be programmed manually? 300sniper G-Code Programing 25 02-14-2008 10:07 PM
code rotary manually daisydog Mastercam 3 01-19-2008 02:20 PM
Manually Change Endmill DroopyPawn G-Code Programing 9 11-20-2007 01:04 AM
How do you move an axis manually ? Eurisko DIY-CNC Router Table Machines 6 04-06-2007 09:00 PM
