Old 12-11-2008, 02:04 PM
alfonsosti is on a distinguished road
Problems with G codes
Hello
I have a CNC Leadwell with a control FANUC OT, we fixed an electrical problem but when we tried to run a program, this one didn't run, basically because all the programs were done with a bad function of the machine, so we tried to modify the programs but when we try to modify a single command, the control didn't accept any change the only change that we can do is erase a complete line.
The original problem was the turrent tool just turn forward so all the programs were done using turrent tool turning formard.
I think that the problem can be produced for some parameter, because several technicians tried to fix the machine changing the parameters but didn't take caution to write down the original parameters that were changed, somebody know what to do to make changes in the programs already done? or I have to write down the programs againg?
Need Help!- M CODES AND G52 fenix728 G-Code Programing 2 11-17-2008 08:03 PM
M-codes and G-codes 4 Matsuura ES-1000V maximusek G-Code Programing 2 11-27-2007 06:41 AM
E1 and G28 codes causing offset problems ? northwestfab Fadal 7 10-02-2007 10:03 AM
MDI Codes Anyone know about them? manyhobies Coding 5 08-03-2007 03:16 PM
g codes AJFab G-Code Programing 1 05-19-2006 08:16 PM
