Old 12-07-2008, 03:50 PM
seanreit is on a distinguished road
What is the gcode to ref 1 axis home after
i run a part? I want my x axis on my lathe to go to the home switch after every run of a part.
thanks,
Old 12-07-2008, 03:58 PM
G28 U0. should do it.
Alternatively G53 X0.
Old 12-07-2008, 04:05 PM
g28 U(as in universe??) 0 (zero)?? I just tried that on my tormach and it did nothing. I didn't think about just sending it to absolute zero, duh, that's a great idea. I would have rather it actually depressed the switch and come back thereby homeing itself, but thiswill work. thanks,
Old 12-07-2008, 04:13 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Turning
"G28 U0" - means go home in X incrementally from the current location
"G28 W0" - means the same for the Z direction
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Originally Posted by seanreit View Post
g28 U(as in universe??) 0 (zero)?? I just tried that on my tormach and it did nothing. ...
I thought U was incremental X on a lathe.
What happens if you just do G28 X? Normally this sends the machine to zero in the current work coordinate system then to machine zero (home). I do not like this because it can cause a crash as it moves to the zero before going home; this is the reason for using incremental because a zero in incrmental means no movement, it (should) just go home.
I much prefer G53 because when you are using the machine coordinate ssystem you know exactly where it is going.
Old 12-07-2008, 04:17 PM
ya, i was running a part on the lathe so i just did the g28 on my mill. anyway, i went to mdi on mach3 turn and put in g28u0 and nothing happened at all.
Old 12-07-2008, 04:18 PM
g530 works perfect, should have thought of that before writing this, but thanks for the additional information on g28, I have not used that before, although in my case it's doing nothing, other than if i put g28 z homes.
Need Help!- Can Bobcad be coaxed into making gcode for a 4 axis hot wire machine? seanreit BobCad-Cam 14 06-03-2010 03:56 AM
Problem- Eztrak X axis will not home sidstover Bridgeport and Hardinge Mills 4 11-11-2008 07:04 PM
Newbie- Z-axis 0 point (home) ? tvdbon DIY-CNC Router Table Machines 3 05-26-2008 02:05 PM
Z axis Home backoff Stevie Mach Mill 1 12-20-2005 05:28 PM
I have a problem with my gcode or my conversion to gcode , everything is tiny? NickLatech G-Code Programing 0 03-10-2005 12:46 PM
