Old 12-01-2008, 11:01 PM
duce00 is on a distinguished road
Mixing x and y pitches? + ball screw care
(Reposted to this forum)
I have downsized my origional plan to build a large CNC router and Im designing a larger X-Y bed for my X2 instead. Since I got the CNC bug Ive been collecting bits and peices (yeah Im a steel yard hound). Right now I have 1.5 precision ground ball screws from a Mori Seiki lathe (yes, I really mean 1.5). One is complete and OAL is 27.875", it also has bearing blocks and bearings. The other is broken and OAL is 26", it only has non-driven end block with bearings. They are definately oversized for this application but dang they are nice and only 17 cents a pound! No backlash, rough spots in travel or bends (even in the broken one).
So I have made some basic models and I think I have a fair idea on how to use them for the Y and Z axis. The broken one can be turned at my college shop (we have manuals and CNC) and it will be the Z. The complete one will be the Y. But here is where all my plans start to unravel...I still need an X screw.
After much research and Ebay watching Im starting to get a little neurodic and its really starting to irritate my family. Maybe you folks can pitch in on this one. Heres some of my questions and general issues.
1) I really want to make my X-Y axis screws the same pitch (5mm) but is it a cardinal sin not to? Can I use a 10mm pitch X screw and a 5mm Y? The 5mm screws that are in the lengths and grade I am looking for tend to get too expensive and I am working on a tight budget. What are the real problems in doing this?
2) Does anybody have some straight info on ball screw maintenance and reconditioning? I dont mean re-grinding obviously. I mean cleaning minor pitting and cleaning. Also nut disssasembly and repacking. What kind of grease is used anyway?
I could throw a few other questions out but maybe I should shut up and listen for a bit.
Old 12-02-2008, 12:42 AM
timlkallam is on a distinguished road
Duce I set you a private message
Tim
Tim
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
roller screw versus ball screw. Paraprop Linear and Rotary Motion 2 04-15-2007 04:21 AM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
