Old 11-29-2008, 10:31 AM
seanreit is on a distinguished road
On the CNC 4 PC breakout board
I want to add spindle control to my lathe which is a monster motor on 120vac.
I suspect startup amps are around 25 amps. What relay or contactor would I need to use to hook up to the cnc4pc board?
Old 11-29-2008, 10:45 AM
Al_The_Man's Avatar
Depending what you switching voltage is, a P&B, Potter & Brumfield PRD Relay series is a good alternative to going with an actual motor contactor.
They come in 12v or 24vdc versions for low voltage control.
A PRD-7DY0-12 is 12vdc coil with DPDT 25A contacts @ 270VAC.
Old 11-29-2008, 10:59 AM
I've got 5vdc readily available, I think if I go with a higher voltage on the relay contactor, I will need an additional transformer, I was trying to avoid that if at all possible. 12 and 24dc and ac relays in this amp range are readily available at mcmaster, I was hopingsomoen here had been down this road before with the cnc4pc breakout boards. Thanks for your suggestion and any follow up information you might be able to add.
Old 11-29-2008, 11:03 AM
Al_The_Man's Avatar
If this is a Tower and not a Laptop, What is wrong with using the PC 12vdc from the P.S. 4pin sockets?
Old 11-29-2008, 11:20 AM
jalessi's Avatar
jalessi is on a distinguished road
Smile
Al,
What about one of these?
http://www.crydom.com//userResources...crydom_ha6.pdf
http://tinyurl.com/5wks2g
$8.00 Each + $6.00 shipping!
Jeff...
Old 11-29-2008, 11:33 AM
Jeff, I ordered one of those, pretty good price! I will see if it works. If anyone else has any other suggestions, please add for those that come in behind me.
Al, you are right, I did not consider all the 12 volt in the tower. Good suggestion.
Old 11-29-2008, 11:46 AM
jalessi's Avatar
Smile
Seanreit,
A more elegant, however much more expensive solution would be a VFD.
Hope the SSR works out for you.
Jeff...
Old 11-29-2008, 11:53 AM
Al_The_Man's Avatar
A SSR should work also, but it is important to incorporate this in the E-Stop string, especially when using a S.S. device, also the E-stop should be hardwire activated.
i.e. not by screen button etc.
I know you can get away without following safety measures on a hobby machine, but the same dangers exist as found on a commercial M/C.
Old 11-30-2008, 03:10 AM
Zumba is on a distinguished road
The 12v from the PC will work fine.
Or get yourself a Meanwell 12v/5v combo power supply. At $25 a pop, it seems pointless to make your own. The external supply will keep everything tidy in your computer tower.
Breakout board, Relays on board? Cooper Open Source Controller Boards 11 06-09-2007 07:55 PM
Which breakout board to use erkiwi Stepper Motors and Drives 2 05-05-2007 02:08 AM
Best breakout board? nate Xylotex 1 01-03-2007 07:39 AM
Breakout Board bkkpool General Electronics Discussion 2 07-28-2006 01:15 PM
Breakout board joecnc2006 General Electronics Discussion 3 06-29-2006 09:33 AM
