Old 11-25-2008, 01:39 PM
Left4Dead is on a distinguished road
Converting a Manual Surface Grinder to a CNC
Is it possible to converting a manual traversing surface grinder over to a CNC driven. It seems that most use surface grinders use hydraulics instead of motors? Whats the reason for this? Thanks.
Old 11-30-2008, 03:14 AM
Zumba is on a distinguished road
Hydraulics are used on the X-axis only. The Z and the Y still use leadscrews.
Is your manual grinder equipped with a leadscrew on the X or a braided cable? Mine is the latter.
Old 04-19-2010, 12:00 PM
Jim Seyller is on a distinguished road
Manual table feed converted to automatic
Hello Left 4 Dead
I worked for Harig Products and know I am working out of my home doing technical support for the thousands of Harig customers through out the USA.
Harig used hydraulics on there x axis for two reasond cost and reliability. On our EZ Surf CNC grinders we also use a hydraulic cylinder with a textron valve and a encoder on the axis so you can program your movements to
.00001. The cost to convert wouldnt be cost effective. You might try looking for a good used Grinder, if you have any questions on what to buy or where to look may give me a call or e mail me you phone number I would be more than happy to help you. Looking forward to talking with you.
Jim Seyller
JDS Technical Support
P: 847 683 0476
www.harigtechsupport.com
jdsserv@aol.com
Cnc surface grinder for profiling Mike Wood General Metal Working Machines 1 04-19-2010 11:06 AM
How does a surface grinder work. SmoggyTurnip General Metal Working Machines 6 02-17-2008 04:57 PM
Please help! Surface grinder questions. tntmachine General Metal Working Machines 5 11-16-2007 12:54 PM
Surface Grinder gbowne1 General Metal Working Machines 12 02-27-2007 11:28 PM
Surface Grinder itsme General Metal Working Machines 18 09-13-2006 12:28 AM
