Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Cutting carbide
    Mar 2008
    Cutting carbide
    Im going to try cutting down an old 3/4 carbide endmill into a ring. Does anyone know if I can cut carbide with carbide or do i need a special tool? Also does anyone know the proper feeds and speeds for it?
    Thank you
    Jul 2008
    india
    use diamond wheel
    as i know about carbides,you cannot cut carbides with carbides,
    i use a diamond wheel to cut carbide ,not to cut actually to shape it .
    it is a copper wheel with diamond abbrasive just like the diamond dressers for ginders.
    Jan 2007
    My experience with this is, if you have a higher grade carbide as a too it can cut the old end mill, but if its lower, the old end mill will just dull the new cutter in seconds.
    -Adam
    www.adambrunette.com - Converting My Harbor Freight X2 And My Jet Jvm-830 Knee Mill, As well as many other projects.
    Registered beege's Avatar
    Feb 2008
    I'd get the hole EDMed out, then finish it with a grinder, CBN or Diamond. Tried turning carbide once with a diamond tool (at the expense of Kennametal, i think it was,,,). Setup wasn't rigid enough. But they told me it could b done.
    Jan 2007
    MI. USA
    The only time you can cut carbide is before it's been sintered (whats known as the green state).
    Once it's been cooked forget it.
    CBN does not grind carbide well, PCD won't cut it either.
    It has to be ground with diamond wheels. If you spin it fast enough (3000-5000 SFM) you can use a natural diamond point and somewhat cut it.
    Essentially you are grinding with a single point tool.
    If you really want to do this you'll need to cut it off with a diamond cut-off wheel and have the hole EDMed in. Grind the ID if you want a smooth finish. This takes a very high speed spindle because the grinding wheel is so small.
    If you have enough time on your hands you could lap the inside smooth with diamond paste and a soft steel pin.
    Carbide rings are normally molded to size with .010 grind stock, then finish ground and polished.
    Bob
    You can always spot the pioneers -- They're the ones with the arrows in their backs.
    May 2007
    Quote Originally Posted by CarbideBob View Post
    While you could argue that this is a grinding process. The cutting speeds used are very slow compared to those typically used in grinding.
    http://news.thomasnet.com/fullstory/9875
    Mar 2008
    Thank you guys for the help.
    Sep 2005
    united states
    If I were planning to create a ring from carbide to wear I would machine an electrode from a very high quality graphite and edm it 1/2 from each side leaving the ring complete except the polishing, then I would expect all polishing done with some diamond compound. I would either wire edm off the blank, grind it off, or just sink edm it off with a blade shaped electrode. The reason I would do it like this is because graphite is easy to machine and edm is very trouble free, the guy running the machine is most often capable of doing other things while it is running.
    Danny
    Oct 2005
    If your finger swellsd, you won't be cutting this ring off like a normal ring could be cut.
    Sep 2005
    united states
    Quote Originally Posted by MrWild View Post
    You would just hit it with a hammer, it would bust right off depending on the wall thickness of the remaining carbide.
    Danny
    Jul 2008
    Carbide rings can be broken with vice grips. Hospitals know how to remove them if your worried about it.
    Sep 2005
    united states
    check out ebay for carbide rings, they sell in the neighborhood of $20
    Danny
  • Page 1 of 2 12 LastLast
    1. Cutting carbide Rod
      By Nitec in forum Toolgrinding & Toolgrinding Machines
      Last Post: 01-23-2011, 07:04 AM
    2. Problem- Cutting steel on lathe with carbide insert. Not smooth.
      By alexccmeister in forum General Metalwork Discussion
      Last Post: 12-04-2008, 09:13 PM
    3. Carbide Cutting Tools
      By John Pepper in forum Product and Manufacturer Announcements
      Last Post: 12-07-2007, 03:47 PM
    4. Will a solid carbide bit cut faster that a straight cutting bit?
      By Apples in forum DIY CNC Router Table Machines
      Last Post: 09-11-2006, 08:10 AM
    5. Cutting or grind slots in carbide cutters??
      By coonhunter in forum General Metalwork Discussion
      Last Post: 03-05-2006, 11:35 AM
