Old 11-24-2008, 09:56 AM
SRT Mike is on a distinguished road
Noise from spindle on Leadwell V-40
I was running a job on Friday and towards the end, there was a strange buzzing sound, different than the normal cutting sound. I shut the machine off and figured I'd look at it today. I ran the spindle at 500rpm - sounded OK. all the way to 4000rpm (what I machine at), sounded OK.
But, I ran another part and a few minutes into a 30 minute machinining cycle, the noise was back... I noticed that when I turn the spindle one direction by hand, every 4th rotation of the spindle nose or so there is a "grinding" feel. It feels just like a bearing.
But it's not every turn... only every few turns. So maybe it's a bearing in the motor and not the spindle? Or maybe a bearing on a pulley?
I am not sure if it's best to try to fix this myself or call in the pro's. I've rebuild a hydraulic actuator on my lathe, and installed axis bearings on this mill, so I am not inexperienced mechanically, but when I hear people talking about shimming to tenths and being super duper careful with spindles, I wonder if it's better to call in a pro?
I also don't understand why the noise in the spindle only comes every few rotations - unless the grinding feel isnt' actually from the spindle bearings. And I don't understand why it only grinds when I rotate in one direction and not the other?
Any ideas or tests I can do to try to narrow down the problem?
Anyone got experience with a Leadwell V-40 spindle? The machine is a 1995 model.
Old 11-24-2008, 10:05 AM
avtechmachine is on a distinguished road
Hello Mike,
It sound like noise from spindle belt?
Ahn Vuong
Old 11-24-2008, 10:14 AM
Thanks for the reply... actually I just finished running a job and it was right back to sounding crappy again... but now when I rotate the spindle it grinds the whole way around and it sounds like it's coming from pretty close to the spindle nose... so I am guessing the lower bearings.
I've heard of people rebuilding spindles... but if I remove the spindle, aren't the bearings exposed anyway? I mean, it seems to me that if I am already taking that out, isn't it just a case of replacing bearings? Is it a job do-able by a person in a few days? Or is this something I should call the pro's in for?
Any ideas what this may cost me? I am hoping it's not going to cost more than $1-2k... fingers crossed!
Old 11-24-2008, 10:26 AM
If the spindle bearing lube by oil you should able to change it your self but if it is grease bearing then you should call the pro's.
Max. 4000Rpm I guess it is oil lube.
I am not sure how much it cost but count on above $2,300
Ahn Vuong
Old 11-24-2008, 10:41 AM
Ahn Vuong
It has a max spindle speed of 6k rpm. I run at 4k just because I run the machine about 6+ hours a day constant (lots of profiling work - but all in plastic, so pretty light duty), so I figure keeping it to 4k most of the time would prolong spindle life.
Your price estimate of "above $2300" is that just to replace bearings? That seems high unless the bearings are very expensive. I've heard that a whole new spindle on a Fadal is around $3k... and bearings for the X and Y axes on this machine were $400. The machine shop next door told me they have had spindle bearings done and it's roughly a days work.
Or perhaps it's just very expensive bearings?
Problem- X2 Spindle Head noise. spaceballs_3000 Benchtop Machines 6 06-10-2008 09:22 AM
Help! Spindle Bearing Noise petriej General Metal Working Machines 2 02-26-2008 01:15 PM
Spindle Noise FXRGUY Daewoo/Doosan 4 01-29-2008 04:20 PM
Way Oil and Spindle Noise ETM Shop Syil Products 14 01-28-2007 09:06 PM
spindle electrical noise balsaman General Electronics Discussion 9 10-21-2003 08:41 PM
