Old 11-23-2008, 12:24 AM
mcm375 is on a distinguished road
Where to buy 24/32 TPI straight-tooth set 131-1/2" Blade? + Q on wavy tooth sets
I am having a torrid time finding a high TPI bandsaw blade in this length. I would like to cut sheet metal very cleanly so I am looking for 32TPI or at worst 24TPI.
Straight-tooth set would be ideal for the clean cut, though I have heard that a wavy tooth set is good for sheet metal? Anyone know much about this?
Old 11-23-2008, 03:17 PM
I did find a reasonably large variety of 100ft rolls here:
http://www.victornet.com/cgi-bin/vic...saw+Coils:1528
Including a 1/2" (.020 kerf) 20/24 VP TPI bi-metal blade which sounds interesting for sheet metal work.
It also appears that Lenox offer a 24 TPI Wavy set in their "NEO-TYPE" model, but have not found where to buy these.
Question on welding blades to length -- are fusion welds sufficient or is filler required? I could do this relatively easily from 100ft rolls or another thought I had was to use multiple smaller bandsaw blades and daisy chain them together to make the 131.5" I need. It seems the higher tooth counts are far easier to find in smaller 30-50" blade ranges.
Old 11-25-2008, 09:28 PM
sodle is on a distinguished road
Very easy to "Propane torch" Braze your own with a kit I found on E-bay last year. PROPANE TORCH, FLUX, silver solder,and (2) jigs for around 40/50 bucks.
I have made a dozen blades and NO trouble! Use some in my shop some in the school shop.
Good luck,Howard
in S.ILL.
Hardinge HLV-H Lathe, change gears, 127 tooth leeputman General Metal Working Machines 6 01-18-2008 07:29 AM
WAVY " x " cut Paul Maguire Commercial CNC Wood Routers 2 01-03-2008 11:46 AM
can I get a 13 tooth timing pulley unterhaus Bridgeport and Hardinge Mills 9 01-11-2006 10:11 AM
Why Wavy? energyforce CNC Plasma and Waterjet Machines 4 10-25-2005 11:32 AM
Cutting A Ten Tooth Spline On Vmc With 4th Axis rrrrrgh G-Code Programing 5 08-19-2005 04:33 PM
