Old 11-21-2008, 12:30 AM
ron2008 is on a distinguished road
Spindle Orientation Question
Is this a problem or not? After the spindle orientation is done and new tool is in the spindle, I can turn the spindle by hand.I put the spindle in low gear, now I can not turn it. When the spindle is in high gear, I can turn it. This is on a Mori-Seiki HG500 CNC. Any comments?
Thanks Ron2008
Old 11-21-2008, 09:01 AM
Al_The_Man's Avatar
On most machines, once the spindle is orientated and the tool change complete, the spindle is free to turn, is the resistance in low gear just because of the back-loading due to the reduction?
Old 11-21-2008, 09:08 AM
Are sure you cannot turn it? Get hold real tight and try real hard. As Al says you are back driving the motor through up gearing so the motor has to turn faster than the spindle.
Mazak PLC maintenance sting_dot Mazak, Mitsubishi, Mazatrol 3 05-03-2011 10:20 AM
Die maintenance ??? dpotts Casting Metals 0 03-31-2007 03:53 PM
Maintenance manual Vince4 Fanuc 0 02-19-2007 05:35 AM
CNC Maintenance shinerbttu Employment Opportunity 0 05-17-2006 10:50 AM
Maintenance Muddywoman Printing, Scanners, Vinyl cutting and Plotters 1 11-13-2004 09:24 PM
