Old 11-20-2008, 10:13 PM
JeffreyMcGrew is on a distinguished road
NC controlled cutting stops...
Looking for a company that makes an NC controlled cutting stop that we could setup on a chop saw to cut pipe to computer-controlled lengths.
I've seen some tablesaw adaptations like this, where the cutting fence is moved via NC, but nothing quite like what I'm looking for. I'm looking more for something for a chop or horizontal bandsaw.
I could fab something up myself, but I'd like to see what's out there.
Thanks!
Old 11-21-2008, 09:14 AM
Al_The_Man's Avatar
I have never come across a this type of feature as universal option, it is usually built in to a particular machine.
It should not be hard to make or set up, two general methods are a shuttle, where a vise is shuttled back and forth and moves forward for the predetermined length, another is a pusher for the whole length and advances pre-determined length for each cut.
The latter is often used on tube cut-off lathe/machines and is similar to a lathe and bar feeder principle.
Old 11-21-2008, 11:36 AM
That's what I'm seeing so far.
another is a pusher for the whole length and advances pre-determined length for each cut. The latter is often used on tube cut-off lathe/machines and is similar to a lathe and bar feeder principle.
That's pretty much the sort of thing I'm looking for. The problem is that the standalone machines I've seen are things like precision cold-cut saws with an CNC infeed. While those look great, it's total overkill for what I'm looking to automate. So I'm thinking maybe I'll just have to fab something up instead with a more simple chop saw sort of setup.
plasmacam stops cutting when air compressor goes on?? ziptie007 CNC Plasma and Waterjet Machines 8 04-30-2008 11:36 AM
I put Carriage stops / E-stops on the x&y Shoptask 1739 Gunmaster....I was bored lol spunky1974 Shopmaster/Shoptask 0 06-30-2007 04:13 PM
cnc controlled mandrel bender controlled by mach3 timmyb199 Bending, Forging,Extrusion... 5 05-30-2007 06:35 PM
X2 Controlled from Head 1 on SR-32 JMS4287 G-Code Programing 1 03-21-2007 11:07 AM
Non-PC controlled Arms Laff Riot RC Robotics & Autonomous Robots 9 04-03-2005 01:20 PM
