Old 11-19-2008, 06:17 AM
Danno is on a distinguished road
What type of oil should I use on ways ?
I have read that some are using chain saw oil !! Sounds Mickey Mouse but if it works, Why not!! Also, it would be readily available. Thanks for any replies, Dan.
www.geocities.com/dantechfab
Old 11-19-2008, 06:48 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
How about WAY OIL
http://www.imperialoil.ca/Canada-Eng...DESFebis_K.pdf
www.integratedmechanical.ca
Old 11-19-2008, 08:00 AM
laka is on a distinguished road
We buy Shell Tonna 68, easily available from the bulk oil distributor. I think it's $75 for 20 litres. Most oils companies will have something similar.
Old 11-19-2008, 08:19 AM
If you are talking about a small hobby lathe why not? $75 worth of way oil would represent a couple of hundred years supply and is a bit of overkill. Chainsaw oil simply has additives to make it stickier and stop it being thrown off moving parts so readily. Using it on ball screws and linear ways would be a bad idea because very likely these additives would eventually goop things up.
Old 11-19-2008, 09:23 AM
DareBee's Avatar
KBC Tools sells it in 1 gal containers for $24
Old 11-19-2008, 09:32 AM
Okay, a five year supply.
I haven't been near KBC for about five years; that's what happens when you go and hire a Purchasing Manager.
Old 11-19-2008, 12:23 PM
DareBee's Avatar
tsk tsk Geof
For the sake of you purchasing managers pay cheque, I hope your employees oil your machines more frequently than that!
My CNCs (when I actually am using them) will use about a gallon a week each. Linear way machines would not use that much though.
Old 11-19-2008, 08:17 PM
Thanks for the tips. I'm about an hour+ to KBC, so needless to say I don't make it there too often either. I'm in the process of re-assembly, so I'm in no big panic right now. I'll use light machine oil untill I can make it to KBC. Dan
Old 11-20-2008, 07:11 AM
DareBee's Avatar
They have shipping
G71 type I and type II cycles sinha_nsit Fanuc 5 11-03-2008 05:34 AM
Lubricating ways tikka308 Benchtop Machines 7 11-14-2007 05:43 PM
ways tim clay Linear and Rotary Motion 0 05-31-2007 10:43 PM
Lapping the Ways on my x2, Help! FroggyOne2 Benchtop Machines 0 05-04-2007 02:03 PM
box ways heilcnc General Metal Working Machines 0 03-02-2005 06:44 PM
