Old 11-15-2008, 12:56 PM
honda is on a distinguished road
Lathe
I have an industrial lathe , which is powered with 550 volts. Im trying to run it home on 220volts, with a VFT and transformer putting out 600 volts. The problem Im having is on my motor the RPMs are 1720-860, its 2 1/2 horsepower, amprage is 2.3-2.4, its a 3 phase motor. My motor has six wires, numbered 1 to 6, I need to know how to figure out high and low side on the motor. The motor is a Lincoln electric motor. I have no wire configuration on the motor.
Any help would be greatly appreciated!
Old 11-15-2008, 01:12 PM
Al_The_Man's Avatar
it sounds like you have a star/delta motor, test the leads and you should have 3 distinct windings.
To select the high speed you will need to connect three ends of each winding together, and input three phase to the remaining three ends.
If it a two speed star motor then generally the custom is to connect 1-2-3 together and input 3 ph on 4, 5, 6,.
Old 11-15-2008, 02:23 PM
lathe
the motr is a two speed
Old 11-15-2008, 03:55 PM
Al_The_Man's Avatar
If there is continuity between all leads then the connections are probably going to be as the last line in post#2.
I assume you are only going to run it on one setting (H.S.) if you have a VFD?
No need for two speed.
Old 11-15-2008, 07:29 PM
lathe
thank for the help-AL-Iwill keep you posted on how thing go
Old 11-16-2008, 04:20 PM
lathe
Thing are working fine thank AL for all the help I used the 456 and closed the 123
