Old 11-15-2008, 09:25 AM
Qwikcnc is on a distinguished road
Cool Phase converter recommendations for CNC mill
I am looking for a good rotary phase converter setup to power a Kitamura Mycenter VMC with the Fanuc OM control on single phase power 220v. I have found that my application needs a 20hp rotary phase converter. Some companies say I need a Voltage Stabilizer and others say their converters don't need it. This means there is wide range of cost. I don't want to buy what I don't need. If anyone has similiar experience running a 3 phase CNC mill on single phase please let me know what works and what doesn't.
Thanks,
QwikCnc
Old 11-21-2008, 07:39 AM
mgb1974 is on a distinguished road
Check out the VFD and Phase convertor Forum.
I got one off of ebay. It was CNC balanced. I do not have a specfic voltage stablizer. I think the phase convertor might have one built in. I checked the voltage coming out and all three legs were within 5% of each other.
Old 11-24-2008, 07:06 AM
hank4655 is on a distinguished road
I've been retired from CNC servicing for 10 years I've used a lot of roto phase back then and had some problems. I am going to do some research on any maintenance problems using the roto phase and will get back with you.
Old 12-18-2008, 08:49 PM
Thanks for your answers. I've decided to go with a DIGI rotary phase converter. Apparently they are reccommended by Haas.
Old 12-18-2008, 10:47 PM
tstom is on a distinguished road
I had a problem with a 20 hp rotary convertor running a 760 Bridgeport would not start the spindle motor above 500 rpm or so turns out there is a bunch of load on the initial start of the motor.... ended up returning it and exchanging for a digital convertor which works perfect I dealt with American Rotary and they gave me full credit when the first convertor didn't work right I also bought the digital through them
Old 12-21-2008, 02:26 AM
aaron p's Avatar
aaron p is on a distinguished road
Im trying to figure out the phase converter issue also.
Ive got 80amp service to my small shop and getting a Mori-Seiki MV-35 from a buddy. I just stumbled across these converters: http://www.phaseconverter.com/cncpro.html
What size do yall think I would need for that mill?
thanks
"We can't solve problems by using the same kind of thinking we used when we created them", Albert Einstein Thinking outside the box 24/7........
wtb: 20 or 30 hp phase perfect phase converter gaugemate Want To Buy...Need help! 0 10-23-2008 12:06 PM
DIY 3 phase converter blackbeard52 Phase Converters and VFD 2 01-16-2008 09:46 PM
VF-2 on a phase converter? Dugg Haas Mills 33 03-04-2007 12:06 PM
DIY phase converter? wyobmf Phase Converters and VFD 9 07-26-2006 04:37 PM
3 phase converter? jevs General Metal Working Machines 5 02-16-2005 01:40 PM
