Old 11-03-2008, 05:39 PM
welterracer is on a distinguished road
Need help with Vibrator Polisher..
Hi.. I am new to the site... (my name is brian)
I am a co-owner of a small powder coating business..
I recently got into ceramic coating and need to build a Vibrator Polisher
I already have a 55gallon metal drum and a 55 gallon plastic drum i want to put inside of it and weld the brackets etc to the metal outer shell
Does anyone have any good plans for building one out of a 55 gallon drum?
Brian
I looking into buying one.. but at $16K i think i could build one for under a Grand..
Old 11-04-2008, 08:05 PM
LUCKY13 is on a distinguished road
I dont know of any plans, but it seems I remember reading of a couple of builds like this. Try a search and see what you come up with, if nothings shows try a search on google.
If I am remembering right they used something like a out of balance flywheel type setup with the barrel built in its own frame, then that frame setup on coil springs on a nother frame. Ofcourse the flywheel was hooked to a shaft running the lenth of the barrel, so when it rotated the barrel, and frame it was in vibrated on the coilsprings. The frame the springs where hooked to was bolted down so it would not walk across the floor. It might even had two flywheels. If enough action can not be gained with a flywheel setup some type of cam acuator could be built. The hard part would be building something that didnt kill itself from all the action.
You must be needing to polish some pretty big pieces to need a 55 gal drum setup. I know you can buy small vibratory setups at Harborfreight for a very small price, but it sounds like they would be to small. Still they are cheap enough that if any of your parts would fit you could afford to buy three or four units with a grand.
Well here is a simple search I did for a Vibratory Polisher and it came up with these 10 threads on the subject of building and operation a vibratory. I dont know if there are any plans in the threads but atleast a few where discussions on building one.
Jess
http://www.cnczone.com/forums/search...archid=2986862
Old 11-04-2008, 10:17 PM
Yes i need a larger polisher.. One to do car headers. snowmobile exhaust.and dirt bike pipes..
I havent found any good helpfull info as of yet.. only pictures.. No measurements on the parts used to make the shakers..
Old 11-07-2008, 06:24 AM
All someone has to do is take 10 minutes of time and measure out the metal for the frame work..
That would help a TON..
Brian
Your thoughts on the perfect variable speed polisher? scootmods General Electronics Discussion 0 05-07-2008 09:51 PM
Looking For Mold Polisher pamcouch68@yaho Employment Opportunity 0 05-04-2006 04:48 PM
Frequency vs amplitude of the vibration for a polisher jkeyser14 Mass finishing equipment/media/stratigies 4 12-25-2005 05:03 PM
