Old 11-02-2008, 12:39 PM
mung is on a distinguished road
What is an Arno mill worth???????
I have just probably made a rather stupid ebay purchase.
Never bought any used machinery before, only bought a three in one machine new and been engineering as a hobby for two years now.
Saw this machine on ebay and made a stupid bid thinking I would not win it.
So now I have a machine that looks like the motor and suds pump have blown, and has a chip in the cross feed leadscrew.
Anyone know anything about Arno machines what this one is and what it is worth?
Is it a buy or a bye?
ID:	68977   Click image for larger version
ID:	68978   Click image for larger version
ID:	68979   Click image for larger version
ID:	68981   Click image for larger version
ID:	68982   Click image for larger version
Old 11-02-2008, 01:35 PM
Karl_T's Avatar
Karl_T is on a distinguished road
That machine is worth about $200 a ton delivered to your local scrap yard. walk away.
Karl
Old 11-02-2008, 03:48 PM
Unfortunatly I have already done the deal but it was sold as working....
I wonder if anyone knows what model the mill is and where to get spares?.
I am going to tell the seller to sort out the motor as he said it was working, but I don't know where to get the spares.
Do Arno mills have a bad reputation?????
I have not found any information on the internet about them.
Old 11-18-2008, 08:42 PM
What sort of accuracy is acceptable for a large mill?
I have been doing a little testing seems the mill axes are not a perfect right angles. I have measured with dti Y axis has 0.01mm in 150mm and X has 0.01mm in 200mm.
Anyone have any advice on adjusting mill. I assume I check the gibs then test again then check the angle change along the whole movement. If its wear on the ways would it be sufficient to give the table a skim?
Anyone even seen on of these arno mills before?
I have only found arno nomo mills mentioned on the net but none that look like this one??
lathes.co.uk has no mention of Arno as a manufacturer.
I cannot find the Arno website?
Old 11-19-2008, 10:38 AM
USMCPOP is on a distinguished road
There was one old post at cnczone.com about an Italian made ARNO.
??Worth Buying?? 1982 Kitamura Mycenter 4 CNC Mill TwiztedFab General Metal Working Machines 2 10-23-2008 11:07 PM
Is this mill worth it MrArmyAnt General Metal Working Machines 13 08-23-2008 03:23 PM
Worth of an old G & L VB-4 VMC? bugzpulverizer General Metalwork Discussion 7 06-17-2008 07:05 AM
Worth anything? krebsatm02 DIY-CNC Router Table Machines 6 04-25-2005 10:49 PM
...is it worth? zeljkov General Metal Working Machines 2 04-10-2004 08:49 AM
