Old 11-01-2004, 07:29 PM
RXTurbo is on a distinguished road
McMaster-Carr Ballscrews
I was just looking at the ballscrews available at McMaster-Carr (to go into a planned very small cnc mill I am building from scratch). Originally I was thinking to go with acme thread and delrin nut, however ballscrews would make life easier for my possibly too small steppers.
When using the 5/8" diameter screw, with the correct ballnut what sort of backlash compensation is required? Should two nuts be used? I have worked out that I can buy all three axis from them cheaper than what I can get just the screw for in Australia which is why I am considering it.
Has anybody else got this set up running their machine?
Ben
Old 11-01-2004, 10:25 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Read this thread- http://www.cnczone.com/forums/showth...l+screws+roton
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 11-01-2004, 11:10 PM
Moondog is on a distinguished road
Hello Ben..
For your Ballscrews and Ballnuts, have you priced the ISEL available from Applied Automation and Engineering in Melb. Ph: 03 - 95455011 ask for Kevin.
I am using the ISEL ballscrews for my Z axis... they are excellent and well priced. Cheaper than McMaster-Carr.
cheers
Old 11-01-2004, 11:30 PM
Hey guys, thanks for that - will give the Applied Automation a call.
Regards
Ben
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Ballscrews or Rack and Pinion? freak_brain Linear and Rotary Motion 31 08-26-2005 04:32 AM
Ballscrews & Backlash rustyolddo Benchtop Machines 24 05-13-2005 01:42 PM
Ballscrews with Fixed-Screw coolman DIY-CNC Router Table Machines 1 04-28-2005 11:03 PM
Miraculous McMaster delivery NeoMoses CNCzone Club House 7 11-19-2003 10:20 PM
