Old 10-30-2008, 04:19 PM
termech is on a distinguished road
Ford brake rotors and drum turning
I have been looking at a smithy granite 1340 Overbed is 13" Would this be enough to handle turning rotors and drums for 1966 to 1973 cars? Is the 1.5 horse power on the granite be enough for turning rotors?
Old 11-07-2008, 12:59 AM
budP's Avatar
budP is on a distinguished road
Yes
Just remember that most if not all are cast iron and a c6 carbide tool works well,
budP
Old 11-07-2008, 07:46 AM
smallblock is on a distinguished road
I started out with a Shoptask 1720 model and recently moved up to their Patriot. Both machines have 17" swing over the bed. I have turned brake drums, rotors, flywheels, clutch friction discs etc. However, keep in mind that I do it as a hobby and for a few race car buddys when they are in a bind. If you are thinking of setting up a shop to turn rotors and drums, 3 in 1 machines are not designed for that type of work. A brake drum machine is very speciallized and has a lot of attachments to make the job faster than a regular lathe. Its a competitive business- the local auto parts store I frequent usually charges 8.00 each to turn rotors and drums. Recently they dropped that price to 4.00 if you bought all the brake parts from them.
Old 11-07-2008, 07:58 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Drums: yes. Disks: no. Thirteen inches is measured over the bed, not the carriage. You won't be able to get the carriage beyond the disk to get to the backside of a disk rotor. As it is, you'll have to do a funky setup to get at the whole front surface of the disk.
You can't get a tool to reach around the disk to do the backside. You don't really want to flip it because it's hard to get it to repeat perfectly (both ops should be done in the same setup).
I had a 16x40 Cadillac lathe and it only barely handled 13" rotors from my motorhome. I had to flip them and was careful about indicating them true before I cut the second side. Also: the cast iron dust is hell on your machine.
If you're going to machine automotive cast iron, buy a purpose-built, brake-turning lathe. They turn up on eBay and Craigslist all the time.
Greg
New Machine Build- 600mm Box bend brake (Finger Brake, pan Brake) RotarySMP Bending, Forging,Extrusion... 20 09-06-2010 10:56 AM
Copper rotors vs. aluminum rotors 307startup Stepper Motors and Drives 2 11-12-2007 07:49 PM
Ford logo Beaker General CAM Discussion 7 05-11-2006 07:52 AM
RFQ Brake Drum Adapter Plates Conner Employment Opportunity 0 11-22-2005 12:21 PM
