Old 10-29-2008, 09:38 AM
alexccmeister is on a distinguished road
Anyone got experience using Makita LC1230 for chopping Al. stocks?
Hi all,
As what the title say. Can I use this to cut solid stocks? Spec says it is fast for cutting angle bars, and hollow sections. Thanks.
Alex
Old 10-29-2008, 11:02 AM
That looks like a chopsaw with an abrasive cutoff blade.
Abrasive blades are totally unsuitable for aluminum.
Probably the best blade for aluminum is the 'triple chip' style that is marked as suitable for non-ferrous metals.
I have also found the common mitre saws are perfectly good with this type of blade and they give the option of angle cuts. I don't have any particular preference for make but choose the one with the slowest blade speed because that reduces the noise a little bit.
Old 10-29-2008, 11:18 AM
Hi Geof,
The saw in the picture is rated at 1370 RPM. Will that be slow enough to chop Al?
Alex
Old 10-29-2008, 11:29 AM
Originally Posted by alexccmeister View Post
Hi Geof,
Alex
Actually you may be toward the other end of the spectrum there, around 3000rpm would be my choice.
Put a triple chip blade on that saw and it would probably work quite well. You would just need to moderate how fast you feed the blade into the material.
One thing to remember is that the slower blade speed sometimes has a greater tendency to grab so you need to make sure the material is securely clamped and you are not holding it in a way that you fingers get trapped if it grabs.
Old 10-29-2008, 12:10 PM
Hi Geof,
Thanks for the advice. I am also looking a horizontal portable bandsaw. Might get one from Singapore if the price is right.
Alex
Inhibit vs phase chopping stragenmitsuko Open Source Controller Boards 0 02-02-2008 11:18 AM
makita router rpm constantly reving up/down any one had this problem? senor J. DIY-CNC Router Table Machines 15 11-24-2007 08:37 AM
Gun stocks lilricky2 WoodWorking 7 10-02-2007 06:57 PM
phase chopping l297+l298 dfv General Electronics Discussion 1 06-16-2005 07:33 PM
RFQ - Makita Router Mount Bracket samualt Employment Opportunity 4 01-25-2005 11:43 PM
