Old 10-27-2008, 10:06 PM
SnapB75 is on a distinguished road
Question Offset Tailstock?
My question is how do I align the tailstock so I am not cutting a slight taper? I tried to line up the markings on the tailstock and I was still cutting a taper on my piece somewhere around .013 from end to end on a 9in piece. Before I adjust the tailstock I measured a .002 taper in a 9in long work piece. I would like to try and get it back in the .002 range or even closer. I have searched on the site and could not find anything that was helpful. I am kinda new to lathe work so any advice would be great! Thanks!
Old 10-27-2008, 10:22 PM
You have taken a test cut and know what direction and how far your tailstock is out of alignment. Now mount a dial gauge on the bed of the machine with the probe touching the side of the tailstock barrel and use the adjustment screws to move the tailstock by half the amount of the taper.
Take another test cut and repeat if there is still too much taper.
On a small inexpensive lathe 0.002" over 9 inches is not bad but you may be able to get it better.
Radius Offset and Length Offset jim_stoll Dolphin CADCAM 13 10-14-2010 07:47 PM
FANUC 3M G54 OFFSET, H-OFFSET----Please help!!! cjchands Fanuc 2 05-25-2009 11:22 AM
M Code for Tailstock? Crashmaster General CNC (Mill and Lathe) Control Software (NC) 22 01-22-2009 03:42 PM
Right pressure for tailstock jani General Metalwork Discussion 12 03-05-2007 10:45 AM
TL-2 tailstock rbest27 Haas Mills 2 11-10-2006 05:20 PM
