Old 10-27-2008, 11:46 AM
BNR_RANDY is on a distinguished road
CNC or auto Surface grinding question
On a CNC or automatic surface grinder when should the wheel advance (crossfeed) over the work, when the table is fully right or fully left. I would think it would be correct to advance the wheel when the table is left so as the table comes back to the right you are making a conventional cut as opposed to climb grinding.
I have my "new" Brown and Sharpe Techmaster in place and need to start using it, while using it over the next few weeks/months I need to correct the programming in the PLC. It was converted to an Allen Bradley SLC 500 plc from its original Modicon.
The programming in it is just enough to make it go back and forth and advance the wheel in incremental mode only. The other crossfeed settings do nothing and the crossfeed STOP button only causes the light to light and does not stop anything at all.
The first item on my list is does it crossfeed at the correct end of stroke?
Old 10-27-2008, 09:44 PM
easymike29 is on a distinguished road
Advance the cross feed at both ends of table travel.
Gene
Surface Grinding neilw20 Syil Products 5 08-12-2008 01:27 AM
Surface Grinding...Coolant Question bremenrules General Metalwork Discussion 7 09-27-2007 11:08 PM
Why is surface grinding so accurate... WilliamD General Metal Working Machines 11 07-22-2007 06:14 AM
Surface Grinding Woes Zumba General Metalwork Discussion 25 03-20-2007 10:37 PM
Quote for surface grinding hoju1301 Employment Opportunity 11 09-06-2006 10:16 AM
