Old 10-19-2008, 03:55 PM
tarek is on a distinguished road
Help for a fellow copper machinist
Hello every one, thi sis my first post and I really need some help from all of you copper machining professionals, I am having problems with a CNC machine custom made for n=my factory that drills a 5mm hole into a solid copper block, can any one tell me what is the suitable cutting speed and feed rate for this process and is there any thing taht I can do to prevent the braeking of the drill ( it breaks after an average of 200 holes). Thank you all.
Old 10-20-2008, 02:07 AM
LUCKY13 is on a distinguished road
You might have better luck getting a anwser in this section ( post your tread in the listed section in this forum)
http://www.cnczone.com/forums/general_metalwork_discussion/
Its a section dedicated to machining operations to help people find how, and better ways of doing such a thing as your disscribing.
It would also help to give more info on the operation like,
How deep is the hole your drilling ?
What type of drill bit you are using ?
How many steppes are you drilling with ( starting drill size, next drill size )
What coolant/lubrication you are using?
What speeds and feeds have you tryed ?
And what was the results of these feeds/speeds ?
I cant anwser the question myself because I have not drilled any copper but if you will post it in the section I listed and give all the info you can these guys can probably help you do it better.
Good Luck, Jess
Old 10-20-2008, 02:24 AM
jalessi's Avatar
jalessi is on a distinguished road
Smile
Email this company.
http://www.cjtkoolcarb.com/index.html
ttrost@cjtkoolcarb.com
Old 10-20-2008, 04:04 AM
ZipSnipe is on a distinguished road
slow spindle speed, lots of coolant and lots of pecking, making sure to retract fully out of the hole to clear chips.
Looking for fellow cnc entusiast in CT TOTALLYRC Mentors & Apprentice Locator 21 01-23-2011 09:29 AM
shop owners/foremen/fellow operators i need input millbastard CNCzone Club House 24 03-15-2010 09:21 PM
Welcome my fellow Europeans CNCadmin Europe Club House 227 10-21-2009 07:49 AM
Greetings fellow craftsmen ARC@Daybreak CNCzone Club House 3 05-30-2008 04:33 AM
Looking for CNC machinist/manual machinist in detroit metro area Runner4404spd Employment Opportunity 4 11-12-2007 12:11 PM
