Old 10-14-2008, 02:28 PM
german is on a distinguished road
need help with a precision spec!
i have interest in a used fadal 4020 the vendor says it has a .0015 repeat in all axis the question is.. is that too much error? or what kind of works can do with that? thanks
Old 10-14-2008, 03:04 PM
JWB_Machining's Avatar
JWB_Machining is on a distinguished road
I'm a novice. What exactly does .0015 repeat in all axis mean?
Old 10-14-2008, 03:32 PM
correction
actually it says "within" .0015" all axis repeat
Old 10-15-2008, 10:22 AM
Just a comment. If the machine POSITIONS within .010" and REPEATS within .0015" it will probably and dependably repeat an error.
Dick Z
DZASTR
Old 10-15-2008, 10:33 AM
Repeat is precision, when the machine moves away from a position then returns to that position, or another position, the repeat is how close it gets.
The way it is phrased here is a bit ambiguous because some people mean it is within + or - 0.0015 with a 0.0015 repeat while some mean = or - 0.00075.
As Richard points out this says nothing about accuracy. If you tell a machine to move exactly 10.0000 inches but the ball screw is inaccurate by several thou it may move 10.005 inches. However this is 10.005 +/-0.0015 (or +/-0.00075) for the machine in question.
It is possible to compensate for inaccuracy by telling the machine to move 9.995" but it is not possible to compensate for the repeat variation.
A Haas machine is normally +/-0.0001 for repeat (precision) and +/- 0.0002 for accuracy (the precision affects both ends of a move that is why the accuracy has twice the precision error, excluding any systematic erros in the ball screw which can be compensated out.)
Need Help!- Need spec of Litton - Clifton Precision JDH-2250-JG-1C wermut Servo Motors and Drives 1 10-16-2009 10:00 AM
Stepper motor spec? benergy Stepper Motors and Drives 3 01-28-2008 04:26 PM
Need Stepper spec/wire help PoppaBear10 Stepper Motors and Drives 0 10-11-2006 09:07 PM
Need to know the spec. of this stepper CrazyRonny General Electronics Discussion 0 05-26-2004 10:28 PM
precision servos (digital) vs. precision stepper (<3.6degree step angle) bennyben Servo Motors and Drives 6 03-05-2004 10:11 PM
