Old 10-14-2008, 12:31 PM
JWB_Machining's Avatar
JWB_Machining is on a distinguished road
ER-16 Collet stuck in ER-16 Tool Holder
Ok, So I'm hoping to remedy this before my boss comes back and gives me a bunch of crap about how much everything costs. I think I put a slightly too large drill bit in an ER-16 Collet. I believe the Largest you can do is .393 in ER-16 and I put in a Bit just under that, .391 I believe. Regardless of this I did some machining with this bit and I went to take it out. I unscrewed the cap and tried to pull the bit out but it wouldn't budge. I continued to unscrew to the point that the Cap and the collet disconnected. (Not Supposed to happen) Now I have the Cap off the Tool holder but the collet is still stuck in the tool holder with the Drill Bit. Is there any trick to remedy this? Old Fashioned Elbow Grease makes me think I'll damage the Collet or the Threads on the Tool Holder.
Please have a solution!!!
Old 10-14-2008, 01:16 PM
I got it out! UNfortunately I had to ruin the drill bit but it was only HSS. I screwed the cap back on and clamped down on the Drill Bit in a Vise. One good swing with a dead blow and it slid right off.
Old 10-14-2008, 02:04 PM
HuFlungDung's Avatar
Moderator
If you screwed the collet nut back on over the collet with a large tool installed, you have probably ruined the nut. It will not extract properly henceforth.
Cat 40 collet tool holder question dlenardu General Metalwork Discussion 2 03-20-2008 02:26 PM
Can I use a collet holder with a lathe? acerocket CNC Tooling 2 10-27-2007 03:07 PM
MT2 er32 Collet Holder dfurlano Benchtop Machines 5 08-21-2007 03:50 PM
R8 Collet Holder Tool Setter Chrisjh Syil Products 12 08-06-2007 08:44 PM
7x10 headstock collet holder? Tim Wiltse Mini Lathe 2 04-23-2007 07:43 PM
