Old 10-13-2008, 11:13 AM
stuby is on a distinguished road
rigi tapping feed speed equasion?
hello all im getting ready to do some rigid tapping but i cant seem to rember or find the equasion to find the corosponding F (feed) and what the S (rpm )should be t tap with my 1/4 20 thanks for your help ahead of time
Old 10-13-2008, 02:47 PM
Bikov is on a distinguished road
I think the formula is F(feed rate)=S(spindle RPM) * Pitch
Old 10-13-2008, 03:24 PM
Correct; 20 tpi is 0.05" x rpm; if you use 1000 rpm the feed is 50.0fpm, if you use feed per rev the feed is 0.05 no matter what the rpm.
Speed & Feed kal_pesh Mastercam 4 02-23-2008 01:19 PM
Speed & Feed kal_pesh General CAM Discussion 1 02-20-2008 10:15 PM
Spindle Speed for tapping 1/4-20 holes. Loading General Metalwork Discussion 32 08-16-2006 09:28 PM
feed and speed / sfm citra General Metalwork Discussion 3 03-17-2006 10:55 AM
speed and feed KBW General CAM Discussion 2 02-20-2004 09:18 PM
