Old 10-24-2004, 09:47 AM
Stevie is on a distinguished road
Ball screw backlash options
Hi Guys
Well i got a long ballscrew off eBay (53" 0.500" dia 0.500" lead 2 start) with a single nut (2 ball tracks)
However there is a fair bit of play in it; Ive not measured it but must be 3-4 thou
So as I got it for a good price i have 3 options (as I can't find who made it for a replacement nut; and i already re-loaded the nut with new balls)
option 1
Toss it
option 2
build it into a third lathe as the Z axis (I'll have to cut it down) and add some form of backlash compensator; this could be a weight on a thin wire rope hanging from a pulley
option 3
I cast a plastic nut with bronze dust mixed into the resin; I've already tried this and other than the shrinkage it will work (I had no dust in it for the test)
I can allow for the diameter shrinkage by wrapping the ball screw with teflon tape before the pour; but it's the longitudinal shrinkage that i can't dream up a way of allowing for
This nut will be following the ball nut with a spring to push the ball nut against 1 side of the threads; the ball nut will be positioned to thrust in the direction of cut; so the backlash is always compensated for (unless your backcutting)
Any ideas guys
Old 10-24-2004, 11:10 AM
HuFlungDung's Avatar
Moderator
You could try here for some oversize balls:
http://www.precisionballs.com/
Its difficult to estimate what size you'll need, but you might be able to come a lot closer than what you have. That's not saying that the internal ball contact angle will be correct if its a crude screw and nut, but, it may get you by.
Old 10-24-2004, 11:27 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Option 4 - How about using a short piece, make it into a tap - and drill/tap deltin/acetal rather than make a cast plastic nut? I and many other here have taken this approach with very good results. Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 10-24-2004, 11:30 AM
Thanks guys
I was told oversize ball did not exist
Old 10-24-2004, 08:43 PM
ger21's Avatar
Moglice. I saw a website before, where they bored out the nut, and injected moglice into the nut while on the screw, so you end up with a ballscrew without balls, and no backlash. But I can no longer find the site.
Old 10-24-2004, 08:52 PM
you mean this
Old 10-25-2004, 07:00 AM
ger21's Avatar
Yes. Give tham a call and ask about that application. I also heard on one of the Yahoo groups that they have packages a limited number of smaller quantity packages, as the price is a little high. I think it was around $50 for the smaller package, but don't quote me on that.
Old 10-25-2004, 01:15 PM
Moderator
Oops, my bad (I quoted him )
Old 10-25-2004, 03:49 PM
D Walck is on a distinguished road
The website for Moglice is www.moglice.com. Hope this helps. d
Old 11-02-2004, 08:40 AM
Swede's Avatar
Swede is on a distinguished road
If the ballscrew is rolled (it probably is) then the backlash that is present is normal. Rolled screws have natural lead variation, and if a ball-nut is loaded with oversized balls, as the nut travels in areas with tighter pitch, then the nut will begin to bind. If you look at Thomson-type rolled ballscrews, they eliminate backlash with spring-loaded double nuts back to back. If it was a simple matter to load oversized balls, then I suspect they'd do it.
Although thinking more while typing ( ) perhaps the hand labor associated with oversized balls makes it cheaper for them to do the double-nut trick, so perhaps oversized balls will do the job for you! It certainly won't be an expensive test, just labor-intensive.
Old 11-02-2004, 10:40 AM
Moderator
Yes, the trick is to guess what size balls to get. 1/8" balls are about 20 cents each, but as Swede says, it would be a lot of trial to load the nut and try it the full length of the screw to find the size that won't bind up anywhere.
It is good to know that every other ball can be smaller diameter. This lets you get away with purchasing only half as many "working balls" as the nut really requires. The small balls act as spacers between the large ones, to help prevent skidding and jamming of the balls against one another (think of what happens when you let your front bicycle tire rub against your buddy's back bicycle tire )
  #12   Ban this user!
Old 11-02-2004, 04:01 PM
The screw looks ground
I'm still waiting to hear from the guys about oversized balls
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Revolutionary Linear Drive System allanconway2 Polls 21 05-03-2009 08:27 PM
Ball Screw Identification BeerFizz Benchtop Machines 2 04-07-2005 10:28 AM
Ball Screw Backlash rocks101 DIY-CNC Router Table Machines 2 03-04-2005 08:35 AM
Need help with Ball Screw Choice samualt DIY-CNC Router Table Machines 5 09-06-2004 07:02 AM
