Old 10-06-2008, 09:42 AM
squale is on a distinguished road
How are the quality of VICTOR lathes versus Grizzly, etc.?
Just looking for a good manual lathe. How is the quality of VICTOR ??
Old 10-06-2008, 04:31 PM
anybody?
Old 10-07-2008, 12:20 PM
USMCPOP is on a distinguished road
I guess it depends on the vintage, etc., as things are always changing. Just because Victors were made in Taiwan at one time, there's no telling exactly where anything is made anymore. They also use the Fortune brand name.
That said, however, the machines made by Victor Taichung have been well regarded for a long time. I know a guy who worked with 3 of the 16 x 40's, I believe. He said the oldest of the 3 was the best, but that all were acceptable.
http://www.fortune-cnc.com/index.php?page=fortune-lathe
Also see http://victor.taiwansource.com/company-profile.htm
Here is a recent discussion of various lathes, including the Victor:
http://www.cnczone.com/vb...t=victor+lathe
I almost bought a Victor vertical mill (Bridgeport style, but a bit heavier), but the timing wasn't right.
Old 10-10-2008, 06:55 AM
polaraligned is on a distinguished road
I have had a Victor 16x60 for about 1 year now.
It is of fine quality. Probably better value than the lesser china brands.
Scott
Old 10-11-2008, 08:58 AM
AppEng is on a distinguished road
I agree. Nice lathes for Taiwan stuff. Shop I used to work at had (2) Victor 16x54's and a Fortune 16x40. All were the same basic lathe- no question. The Fortune had cog belt 'gears', ran quieter, and was easier to change over, while the Victors had straight cut gears, and were a little noisier if you didn't mesh the gears well with paper when changing ratios. I hear the newer varieties have a metric/sae lever instead of having to change end gears to cut metric threads...a big time saver.
That said, they were smooth (smooth enough), and cut accurately. I'm not sure of their HP, but I stalled every one of them- admittedly taking very heavy d.o.c's. The steady rests had roller bearings instead of bronze bads which worked real well. If you get into heavy interrupted cuts/out of round parts, you'll notice some lack of ridgity and mass. All 3 had an 1800rpm top speed, which I rarely ever got up over 1200- it really sounded like they were winding up, and took too long to get there for start-stop work. I used to do some toolpost grinding on the newer Fortune lathe (only one with a dro), and it worked well and was repeatable- for a toolpost setup. The coolant sumps were hard to clean out, so I used to pump out thru the machine's hose, then shop-vac the crap out of it. I worked in that shop for 9 years, and never had an issue with any of the machines that I can remember.
Just my input!!
Need Help!- VICTOR VMC rajesh_1355 Fanuc 3 11-03-2008 07:05 AM
What features are mini-lathes missing versus larger industrial lathes? squale Mini Lathe 8 10-08-2008 07:58 AM
Any opinions on the Grizzly g4016 lathe or other Grizzly lathes? DublD General Metal Working Machines 3 11-26-2006 01:23 PM
Mister versus flood versus ??? coolant system split63 Bridgeport and Hardinge Mills 14 10-02-2006 06:18 AM
Quality of Enco lathes? Neil_J General Metal Working Machines 5 11-30-2005 08:02 AM
