Old 10-03-2008, 09:17 PM
mjrockwellus is on a distinguished road
Kitamura Mycenter 1 480 volt to 240 volt conversion?
I have an opportunity to get a Kitamura Mycenter 1. It is a 480 volt machine but I only have 240 available. Does anyone know if it is possible to switch the machine to run on 240?
Thanks,
MR
Old 10-21-2008, 11:56 AM
bunk7575 is on a distinguished road
The easy way to fix this is to look on ebay and find a 480 primary and 240 volt secondary transformer should be able to find one for few hundred dollars and wire it up backwards, like hook your 240 volt to the secondary and it will give you 480 volt out the primary and you can hook that to your machine ready to go and it will be clean....a 35-40 kva would be more than a enough to do the job... depending on the size or the machine
Old 10-21-2008, 12:14 PM
Al_The_Man's Avatar
If it is Fanuc based, it possibly has transformer taps for 220, if there are any 3 phase motors on 480, they often are dual voltage, 220-480, you might have to change the overloads/fusing, if changing over.
Tags
kitamura 480 240
Kitamura Mycenter cdlenterprises General Metal Working Machines 2 11-19-2007 11:25 PM
Kitamura Mycenter 3B sebaja General Metal Working Machines 0 10-16-2007 06:22 PM
kITAMURA MYCENTER-1 Help needed again!! aghobby Fanuc 5 07-11-2007 03:53 AM
Kitamura Mycenter 0 inertialabs Shopmaster/Shoptask 0 01-15-2007 09:47 PM
Kitamura Mycenter 1B Specs Nauticalknowhow General Metalwork Discussion 1 12-27-2006 01:03 PM
