Old 10-01-2008, 08:35 AM
AppEng is on a distinguished road
Rig/Move Bridgeport Mills...How??
I recently bought a B.Port Series 2 R2E4 CNC mill and a South Bend Chipmaster II mill at a local auction and expect to be picking them up within a week or two.
I'm looking for a little advise as far as rigging.
I have a 1ton truck/trailer that I'll pick them up with, loaded by seller. Where are the usual strapping/chain-down points for transport? When I get them back to my pole barn, I'll have a chain hoist or hopefully forklift available for unload off the trailer. I'd like to have some sections of small dia. pipe available and a pivot lever once I'm on the ground.
I've worked for a CNC machine tool builder before doing installs, maintenance...etc, but I usually let the hired pros take care of the moving.
Where are the pick points and safe areas to strap/pick up/chain down?
Any advise is greatly appreciated! Thanks!!
Old 10-01-2008, 02:33 PM
123CNC is on a distinguished road
rigging
I'm not sure on BP S2, but series 1 and clones usually have a thread hole top-middle of ram for an eye-bolt. Nice place to lift and chain down during transport. Riggers like to strap tight across the base - foot, I prefer over the ram (eye-bolt) or neck, between head and ram, but would also do across the foot, extra chain or strap permitting. And of course both forward and rearward tie-downs to prevent forward/aft movement.
It seems all the riggers like to lift knee mills with forklifts under the ram, lifting from the side. Some use wood to protect the ram slides, others don't. If a tight clearance, i.e. narrow doorway, 2 4x4 or bigger across the forks and under the front and back of the ram, lifting from front or rear of machine.
Lifting from under the base can be done, but being top heavy machinery it is not advised.
Need Help!- Bridgeport EZTRAK Alarm: commanded X-axis move too far positive Pribbs Bridgeport and Hardinge Mills 4 01-23-2009 09:34 AM
Splash Guards for Bridgeport Type Mills widgitmaster General Metal Working Machines 2 05-15-2007 01:54 PM
so how do the square column mills compare to a bridgeport?? fast89 Benchtop Machines 12 03-21-2007 12:49 AM
Face Mills intstead of end mills balal General Metalwork Discussion 8 07-01-2006 01:35 AM
The X-Axles... to move or not to move! Wild4aces Mechanical Calculations/Engineering Design 1 03-18-2005 02:26 PM
