Old 09-30-2008, 10:24 PM
boy_gameover is on a distinguished road
Help !! Sherline 5100 or MSC BENCHTOP MILL DRILL
Hello ! I need to buy a milling machine for making water block (copper ,brass ,aluminum..and hard steel ) .I see this mills machine but i don't know which one is strong enough to mill copper 1/2" thick or less .....
+ Sherline 5100http://www.sherline.com/millinst.htm
$400 for the used one
+MSC BENCHTOP MILL DRILL MILLING MACHINE W. R-8 SPINDLE
1HP MILL DRILL WITH R-8 SPINDLE (USES THE SAME TOOLING AS LARGER BRIDGEPORT STYLE MILLS) 20-1/4X6-1/4 TABLE, X TRAVEL 12-1/4, Y TRAVEL 5-3/4, 17-1/2" MAX UNDER SPINDLE NOSE TO TABLE
This MSC bench top mill/drill is close to my house .It is weight about 660 pounds with stand .
It cost about $650 but it is used , it is listed on Ebay so i can deal with the seller ,and may be he will discount for me without using Ebay and Paypal
I don't have any imformation about MSC bench top mill/drill but I think it is the same with this one
http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=50995200
One more thing ! May be i will need a CNC machine for later ,so which one can cover to CNC .
Please help me !!.Thanks
Old 10-01-2008, 11:31 AM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Sherline is a good machine, but small. It can only take very light cuts, it's designed for jewelry and small objects.
Don't bother with the second machine.
The last machine for only 200.00 is the way to go, it's bigger, more rigid and do what you want, quicker then the other two. It's the better choice and can be cnc'd as well. They can all be CNC, but the last one will be your best option.
-Jason
Old 10-01-2008, 04:33 PM
-Jason
Thanks Jason , but the last one you are talking about is cost ~$1700 not $650.I can not spend that much money .That is the same with the old MSC bench top mill/drill which looks dirty and ugly (can be seen with more pics ).
Any1 help me please ??
Old 10-01-2008, 05:17 PM
Oh sorry about that. You need an X2. You have a small budget and the x2 sounds like it will fir your style. But importantly, what is your working cube???
Oh and unless you get a big mill weighing 500 pounds plus, your not going to cut through 1/2in copper anyway. You need to do this in multiple passes.
If you have the X2 work cube, get that.
Numerous thread in Benchtop forum.
-Jason
Old 10-01-2008, 09:54 PM
ZipSnipe is on a distinguished road
For making water blocks that MSC mill will be fine. Look at the travels you get. The only drawback is if you were milling lets say a large workpiece and you had to flip it around . Which you would then need to raise or lower the head which then in turn means you have to re-zero the part back in. But for water blocks which are small work pieces you wouldn't need to raise or lower the head. The spindle has a fine feed on it which will be fine for what your doin. I have the Sherline mill and I have used it to cut steel and if I wanted to make water blocks(which is the original reason I wanted to get into machining and cnc) I could use the Sherline for that too. But bigger is better unless space is a factor. I'd go for the MSC.
Old 10-01-2008, 10:54 PM
Thanks everybody .I will deal with the guy who is selling MSC mill .May be i can get a better price .
Mori Seiki Dura Vertical 40 x 20 Model 5100 highspeedmike Haas Mills 5 06-26-2010 08:44 AM
Need Help!- RF BenchTop Colume Mill/Drill Post Headaches skip20 Benchtop Machines 18 04-19-2008 12:01 PM
Turning a benchtop mill/drill into a lathe? tootalew General Metal Working Machines 5 11-28-2007 08:10 PM
BenchTop Mill to Buy leeschaumberg Benchtop Machines 8 04-10-2007 05:57 PM
Drill holes with end mill or twist drill ? Argofanatic General Metalwork Discussion 15 12-29-2006 11:05 PM
