Old 09-30-2008, 04:53 PM
Mike Wood is on a distinguished road
Cnc surface grinder for profiling
I have access to an old harig 612 surface grinder and was wondering how feasible it is to cnc this machine and what it might take to do so. The primary focus would be to profile grind ‘wood molding’ and shaper knives for myself.
My thoughts are to cnc the x and y axis, and install a VFD on the spindle to slow it down. I suspect the y axis screw could be replaced with a small ball screw and the x axis cross slide cable mechanism could probably be used as is, as it seems to have minimal backlash. However, I'm not sure if it will work in the end.
I'm new to this and would appreciate any advice or suggestions: Is it feasible? If so, what type of ball screw? What size servos? What type of VFD is appropriate? Etc.
Mike
Old 04-19-2010, 12:06 PM
Jim Seyller is on a distinguished road
Harig Handfeed conversion
Hello Mike
About myself. I worked for Harig for 43 years, I built machine, designed mechanical and electircal and my last 20 years I did the phone technical support. Harig closed the Elgin plant as of 12/29/09, I know am working out of my home office doing the same work and enjoying it.
Converting a handfeed grinder into a cnc machine is a major task unless you are very mechanical and electrical. Please e mail me your phone number I would like to spend some time explaining my thoughts on this. It will be easier for you and I if I talk to you over the phone rather than e mail.
Best Regards
Jim Seyller
P: 847 683 0476
www.harigtechsupport.com
jdsserv@aol.com
Problem- Unknown surface grinder in need of tlc jacek General Metal Working Machines 3 04-12-2008 01:38 AM
How does a surface grinder work. SmoggyTurnip General Metal Working Machines 6 02-17-2008 05:57 PM
Please help! Surface grinder questions. tntmachine General Metal Working Machines 5 11-16-2007 01:54 PM
Surface Grinder gbowne1 General Metal Working Machines 12 02-28-2007 12:28 AM
Surface Grinder itsme General Metal Working Machines 18 09-13-2006 01:28 AM
