Old 10-21-2004, 06:07 PM
ML1 ML1 is offline
ML1 is on a distinguished road
power of milling motor
Hi all.
Like a lot of you here, I also want to build a milling machine. and what I think is as standart procedure is to start with some calculations. I did a few. and I was wondering what kind of motor powers you are using.
I calculated that a milling machine capabel of milling a stroke 5mm and 5mm deep in standart C45 steel with a fz of 0,2mm and a vc of 0,6m/s would need a motor with 3800W. could I calculated it correct???
and what kind of motor power are you all using.
Greetings Maarten.
P.s. if there are some mistakes in my english, don`t judge me.....
Old 10-21-2004, 06:20 PM
Gold Member
JFettig is on a distinguished road
your saying you want to mill 5mm deep with a 5mm end mill in steel? Thats not too good of an idea unless its a rougher, and if it is, it doesnt take quite as much.
I dont know how big of a machine your looking to build, but now that I think about it, My machine only has a 450w motor on it, its a seige x2. I havent milled much steel on it though, you need to run it quite a bit slower than how I run it. The way I have my pully ratios wouldnt be good for milling steel.
I used a 3/8" rougher in some steel just surfacing some bar, I took about .05" wich is nothing at a decent speed, seemed to handle it alright.
But, of course, more power is better I do want to get a bigger motor some time or another.
Jon
Old 10-21-2004, 06:25 PM
ML1 ML1 is offline
yah... I just watch another time trouch my calculations, and I took a speed from 0,6m/s but this is much to high. so I turned it down to 0,01m/s and now I only need a power of 63W....
that sound a lot better
Old 10-22-2004, 05:26 PM
Stevie is on a distinguished road
the rule of thumb is the diameter of the cutter is about the max depth of cut
A ripper cutter (the type with serrated edges will take more; I take 1" regular with a 3/4")
But the speed is important; most CNC operators use way too high of a spindle rpm
for a 1/4" 2 or 4 flute end mill I use 800 rpm and can take the full depth
Bipolar Stepper Motor Power Supply mdframe Stepper Motors and Drives 13 01-27-2006 11:50 AM
Driver and Motor Power On Dangers mannster General Electronics Discussion 3 04-23-2005 03:26 PM
what is the power of this motor? SJ781 Servo Motors and Drives 3 05-18-2004 10:59 AM
Spindle power by servo motor Stevie General Metal Working Machines 4 04-18-2004 02:20 PM
