Old 09-26-2008, 07:35 PM
sfilippo is on a distinguished road
Resetting Tool Eye Parameters - The Simple Way?
Femco Durga 12e with Fanuc Control.
Hi Everyone,
Let's say I want to get my Tool Eye working correctly again. I like touching off my tools so I could care less, but for resale value, it would be a plus for it to work right.
What if I set my Tool Eye Parameters to 000000 and then teach the tool with it. Then make a cut and measure. Take the difference between my measurement and the Machine's Position, convert it to Metric and Wha-La... The new Tool Eye Parameter???
I don't know if that will work, but it seems so much easier than adding or subtracting the amount of error to or from the existing Parameter.
Maybe it's no big deal either way for most here?
I'd like to know if my above way would work or not. I'd try it out if I were the Supervisor where I work, but I'm not, so I'm left to wonder about this.
It must be simple...Or is it?? Change tool direction? teamtexas Mach Mill 0 09-09-2008 09:03 PM
Need Help!- Fanuc OM tool change parameters Maguillacutty Fanuc 1 09-08-2008 10:32 AM
Changing/resetting the table position during a tool change? Jim Ster Mori Mills 2 08-13-2008 08:31 AM
Coding tool load values with parameters? mystiks Daewoo/Doosan 2 12-31-2007 12:03 PM
Tool holder dimension parameters? MichaelHenry SprutCAM 5 12-23-2006 03:43 AM
