Old 09-22-2008, 12:27 AM
Scott Kelley is on a distinguished road
Bijur Pump - Wiring?
I am retrofitting a Bridgeport Boss mill with a PC controller. Unfortunately, I have only some of the wiring diagram sheets for this mill, and that does not include the oil pump.
The pump has 4 wires going into it, 2 (black & white) connect to what looks like a gear-motor, and 2 (red & green) attach to yellow wires that go into the body of the oiler. Anybody know what the appropriate inputs are?
Thanks,
Scott Kelley
Old 09-22-2008, 02:37 AM
123CNC is on a distinguished road
Pardon me, do you have any Bijur?
Many Bijur variants, but on my early Boss the synchromotor (gear motor) was 220 (some 110) connected to the black and white, and IIRC red and green wires to a low level sensor. I don't remember if NO or NC, but just a discrete float/switch you can wire either way.
Perhaps which Boss model your dealing with might help others to confirm if this is true for your yellow situation. But you could take an ohm reading across the two and lift the top of the pump to simulate low and you will be able to verify (no power, yellows to red&green wires disconnected.)
Bijur Spraymist Woes Chris64 General Metalwork Discussion 9 08-12-2011 09:03 AM
Bijur oiler adjustment sharp-shooter Bridgeport and Hardinge Mills 3 08-29-2008 11:34 PM
BIJUR OILER tpmx57 Bridgeport and Hardinge Mills 5 06-08-2008 05:33 AM
BOSS 5 Bijur oil pump help braidmeister Bridgeport and Hardinge Mills 8 05-31-2006 01:01 PM
Bijur Fittings arsenix Bridgeport and Hardinge Mills 12 10-12-2005 08:36 PM
