Old 09-19-2008, 07:04 AM
pinkminky is on a distinguished road
Thumbs down Fitting a door interlock to a Fadal
Hi , im struggeling to find a way to fit an interlock to a Fadal. The machine still operates when the doors are open. Causing health and saftey issues.
It is possible to fit an interlock thorugh the emergency stop switch , which puts a break on the spindle. But using this method would stop the machine each time doors are opened making it viable to have to jog the machine each time to stop the machine bombing out. This would waste alot of operators time.
Is there any other method of doing this?
Many thanks
Sarah
Old 09-20-2008, 01:23 PM
BAD DOG is on a distinguished road
INTERLOCK
YOUR MACHINE CAME WITH ONE, OR HAS ONE ON IT AND IT IS DISCONNECTED.
LOOK ON TOP OF THE DOORS( WHERE THEY MEET WHEN CLOSED) ,,, THAT IS WHERE THE INTERLOCK IS LOCATED,,
CALL FADAL AND THEY WILL HOOK YOU UP.
BAD DOG
Old 09-22-2008, 03:03 AM
Inter lock
Thanks for getting back to me.
The machine originally had a lock on it, but for some reason it has stopped working. Allowing the operator to open the doors mid cycle.
A Fadal engineer has been to have a look and reccomended wiring in a lock, connected to the e-stop. This is not a good fix !
There must be some electronic switch in the back that has broken or something that stops the lock operating. This is a very old machine,
Many thanks
Sarah
Old 09-22-2008, 03:09 AM
ZipSnipe is on a distinguished road
Many thanks
Sarah
All the mold makers I work with, had the interlocks disabled for a reason. So they could open the machine up while its running to make adjustments to airline or coolant lines without having to restart the machine up or reload the program. Does the door want to stay open?
Old 09-22-2008, 08:12 AM
The doors must stay closed whilst in cycle. Health and safety issues.
Cheers
Sarah
Old 09-25-2008, 04:41 AM
Oh they keep them close, its just sometimes they need to open it for a minute to make adjustments. If they left the interlock attached to the sensor, it would shut the machine down each time the door would be opened. Not very profitable! The business(machine work in general) is just not healthy to start with. Are you guys milling brillium? Our guys wear respirators when working near that stuff, even if they open the machine for a second.
Old 09-25-2008, 06:41 AM
Hey,
If i had my way i would have them open to. But we employee not so skilled people to operate the machines (large production) so health and saftey is critical.
No Brillium just aerospace garde materials like ali, inco, s/steel.
Thanks for your help.
Sarah
Old 09-25-2008, 08:36 PM
What about just adding a magnetic catch? http://www.mcmaster.com/
Just type in magnetic catch
Old 10-01-2008, 07:21 PM
MarkT is on a distinguished road
Sarah,
Actually the intial advice given you was pretty close to how many of the interlocks are wired on most machines. Most machines have a 24v DC safety circuit, the estop is found on this circuit also. When the circuit of the interlock is broken ( i.e. the door opens) the machine halts. Thats how they are desined to work. Are you asking what to do to replace yours that is missing, or just for a mechanical lock to keep the doors from opening?
Mark T.
www.cnccustomservices.com
Old 10-03-2008, 12:26 PM
milldoe is on a distinguished road
employee better employees if they cant handle opening the door while the machine is running
Door interlock bypass? gearsoup Mori Mills 6 12-09-2008 01:25 AM
Door Interlock override ? 18i-TB YARKONE Fanuc 5 06-22-2008 09:11 PM
Door Interlock hatchmar Fanuc 5 12-29-2007 07:52 PM
Okuma door interlock problem ktb100 Okuma 1 03-30-2007 12:31 AM
Door interlock? Edster Fadal 9 04-05-2006 06:13 PM
