Old 09-15-2008, 01:59 PM
akschu is on a distinguished road
What are the dissadvantages of CNC conversion.
Forum,
I just picked up a G0602 lathe and am looking at CNC conversion. I'm good with metal working (not machining yet) and am also good with electronics and computers, so I would do the conversion myself, but I'm not understanding why you would want to remove the follower rest and tail stock. Don't you need that to cut material that tends to bend such as thin aluminum?
Also, do you give up the ability to do quick cuts? Does everything need to be put in the computer? Or can I get a pulse generator like this one: http://www.cnc4pc.com/Store/osc/prod...roducts_id=160 for doing quick cutting?
Thanks for the answers,
schu
Old 09-15-2008, 02:14 PM
Al_The_Man's Avatar
A lot of CNC lathes still use a steady rest and tail stock.
The compound rest is usually removed as generally not needed on CNC, With this removed, I put on a one size up, larger Tool post on, this allows the use of larger existing toolholders etc.
You can use a PWG for cutting if you wish, although MDI is probably preferred if practical.
Most PWG only allow 1 axis at a time, unless you had a system that accepted two, to more simulate the manual hand wheels.
Old 09-15-2008, 03:43 PM
sharpshooter90 is on a distinguished road
You would retain your steady rest and follow rest just like a conventional lathe. You could use a turret style toolpost for CNC work, as the CNC will generate any angle you want, however if you just wanted to slap a piece in the chuck and bevel the edge, the CNC would be time consuming, while an old fashioned compound would be fast, so retaining the compound is the most practical choice. Most guys going CNC will put ball screws on the machine, which will gut your thread cutting gearbox and 1/2 nut, costing you those functions, but MachIII can cut threads under CNC control. If you use steppers with double shafts, you can attach handles for simple manual turning.
Old 09-15-2008, 05:23 PM
I'm real green with this lathe stuff, so I went to look at what a turret style post is and I see that it has 4 positions and allows for quick change.
So the question is, what is the difference between a turret post and any other quick change post like a phase II other than it holds 3 more tools?
Also I looked up what a compound rest is and see that it feeds the tool along the material being machined at an angle. So it looks like I'll loose the ability to cut a chamfer, taper, and thread without using CNC, but for everything that works at a 90* to the bed I'll be able to cut manually with double shaft steppers.
Did I get that right?
Old 09-15-2008, 06:05 PM
Al_The_Man's Avatar
The tool post I put on was a Phase 11 QCTP, (quick change), I don't regret that.
Unless you intend doing some manual maching, IMO, the compound rest can come off.
Your choice.
Usually with full CNC, you can get creative with macro programming for one off jobs,
I agree it may take a bit longer, but you get the repetitive accuracy of CNC.
Everyone has their preferences.
Old 09-15-2008, 07:15 PM
What about the quick change post that grizzly sells? I can get it for $82 at www.cdcotools.com. Is there an advantage to the phase II over that post?
servo conversion vs stepper conversion contractdesign Bridgeport and Hardinge Mills 3 07-26-2008 03:54 PM
Newbie- IH DIY CNC conversion richardsohn Industrial Hobbies (Support forum) 8 05-20-2008 10:04 PM
Conversion gerrieg CNCzone Club House 0 05-03-2008 03:39 AM
a conversion Kit for CNC US-GUN'S Benchtop Machines 5 08-10-2006 11:23 AM
CNC conversion kit JFettig Mini Lathe 21 01-02-2005 10:06 PM
