Old 09-11-2008, 12:05 AM
DennisCNC's Avatar
DennisCNC is on a distinguished road
Gear cutting machine?
Does the machine in this video rotate the gear blank synched to the cutter or does the gear cutter rotate the gear while cutting?
Dennis
Old 09-11-2008, 12:26 AM
HuFlungDung's Avatar
Moderator
I believe that the work spindle and the cutter spindle are geared together so that the hob does not actually drive the gear blank. This ensures that the teeth on the gear stay straight and that the pitch stays exactly correct (a whole number of teeth) in 360 degrees.
gear cutting ktmodelshop OpenSource Software 4 01-04-2009 08:05 AM
Need Help!- Gear Cutting Martin Long BobCad-Cam 13 08-25-2008 10:08 PM
Gear cutting on the X3 CNC John S. Benchtop Machines 6 12-07-2007 08:26 PM
Gear Cutting chuckknigh DIY-CNC Router Table Machines 12 06-01-2004 07:30 PM
Gear cutting danswen General Metalwork Discussion 1 11-04-2003 12:27 PM
