Old 10-13-2004, 02:12 PM
scuba is on a distinguished road
Grid Shift
Please could you explain what is ment by Grid shift, I had to alter the grid shift after replacing a Fanuc servo motor, Thanks
Old 10-13-2004, 03:50 PM
Al_The_Man's Avatar
Grid shift is applied when you need to move the actual zero point that occurs when you hit the marker pulse on the encoder, some times this zero point needs to be moved a from the phyisical position without the need to start messing around by trying to do it mechanically.
A typical example is when a Z axis encoder is replaced and the Z position has to be in an exact spot for the tool changer function. The difference is measured and then plugged into the grid shift parameter by encoder counts for that axis, so that this value will be added or subtracted from the actual zero home position by marker..
Al
Any ideas for open source CAM package? galacticroot OpenSource Software 26 10-22-2007 11:35 AM
no grid ?? chrisw765 Carken Products (Deskam, DeskCNC etc) 0 03-17-2005 11:59 PM
