Old 09-03-2008, 11:50 AM
cncor is on a distinguished road
Low and high speed spindle motor
I would like to use one motor on a mill capable of doing low speed and high speed stuff.
So I would like a speed range of about 500rpm to 20000rpm or so.
Can I use a HF spindle that does 18000rpm at 300 Hz and use a frequency controller to generate 10Hz to 300Hz for a speed range of 600rpm to 18000rpm?
Does that makes sense?
Do I have any power left at 600rpm?
Anybody already did this before with success?
Old 09-03-2008, 11:23 PM
Jason3's Avatar
Jason3 is on a distinguished road
Generally, a spindle capable of 20,000 rpm will have a low end minimum of around 2,000 rpm. Usually unless it is a pretty big (2-3 Hp +) HF spindle it won't take a cutter bigger than 1/4" anyway so you might not need less than 2,000 rpm - 2,000 rpm and a 1/4" cutter will deliver 130 SFM, slow enough for most materials, and if you need less you can use a smaller cutter perhaps...
Regards,
Jason
Add DIY high speed spindle? bseibenick General Metal Working Machines 11 12-08-2009 10:35 AM
My new High Speed Spindle Jay C Benchtop Machines 19 10-26-2008 10:24 AM
High speed spindle yngndrw General Metalwork Discussion 9 06-26-2008 04:19 PM
High speed spindle... how high? jonesja2 General Metal Working Machines 0 06-04-2007 08:18 PM
High Speed Spindle for Taig - Brushless Motor? GammaWill Taig Mills & Lathes 14 03-29-2007 04:43 AM
