Old 09-03-2008, 07:58 AM
dreamci is on a distinguished road
difference between mill and router
hi can anyone tell me the difference between a cnc mill and a cnc router please. thanks
Old 09-03-2008, 08:11 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Both involve a computer controlling cutter movements in many dimensions.
A router is for wood and light metal like aluminum--and so does not need to be quite as rigid as a mill--So bearings and mechanical drives can be much different. A mill is for metal and, depending on its size and rigidity--Steel and harder metals.
A router usually does not need as much Z height as a mill--and can have WAY larger X and Y dimensions. It may have much higher spindle speeds.
In a CNC mill, since the travel distances are relatively small, rapid speeds are not as important. But in a router, with much LARGER travel distances--High rapid speeds are desired.
When it comes to the CNC electronics, drives, motors and software, they are VERY similar.
CR.
Old 09-03-2008, 09:11 AM
CncLite1 is on a distinguished road
Mill vs router
I would add .. that
Mills typically are designed to hold very tight tolerances .. where routers are not.
Mill +/- .0005
Router +/- .008
or there abouts
Old 09-04-2008, 03:29 AM
great explanations it made me very clear thanks
Old 09-04-2008, 04:07 AM
mechatronicsman is on a distinguished road
Also isn't a major difference that "mill" is used for machines with stationary cutter while the work table is moving, and "router" describes a machine with moving cutter head over a stationary work holding table? Or is that just my understanding?
-bjorn
Mechatronicsman
www.hobbymechatronics.com
Old 09-04-2008, 04:21 AM
Old 09-04-2008, 04:59 AM
CarbideBob is on a distinguished road
-bjorn
Nothing says a milling head can't be moving around.
Gantry mills are just like big routers. A friend of mine has two of them, 5 axis, 15ft x 10ft x 6ft, 40HP 30,000 RPM spindles, and all linear motor drives. (oh yeah, and just under a million and a half dollars each)
Mills are bigger, heavier, more powerful and usually more accurate than routers. Mills and routers are just designed for different purposes.
Bob
You can always spot the pioneers -- They're the ones with the arrows in their backs.
Router vs. mill Ugilten DIY-CNC Router Table Machines 14 08-09-2009 12:23 PM
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 07:31 AM
Difference between mill and lathe MBG G-Code Programing 8 05-28-2008 12:18 PM
CNC Mill or CNC Router? spacifique1 Australia, New Zealand Club house 3 03-16-2007 12:59 AM
Difference between a $70K and $12k router. tltaylor Commercial CNC Wood Routers 15 12-09-2004 08:41 PM
