Old 08-28-2008, 01:24 PM
hotponyshoes is on a distinguished road
Reversing a 3-phase motor - switch question
Hi all,
I know you can change the direction of a 3-phase motor by swapping 2 of the phases,
I also think you can get a rotary type switch that has a off position in the center and runs the motor in either direction depch way you turn it.
Does anybody know the correct name for this type of switch and a good source for them?
Thanks!
Old 08-28-2008, 01:37 PM
Al_The_Man's Avatar
Either remotely by reversing contactors, these are two contactors that are mechanically and electrically interlocked and coil energised, a source is ebay.
Or a reversing drum switch, these are sold by Square D and others. Ebay Item 230285694964
Also you can get mechanical Push Button station, which either of the three phase switches are picked up mechanically by PB.
Can I convert single phase motor to three phase? Jim Estes Phase Converters and VFD 30 01-24-2009 02:41 AM
Lathe spindle reversing question. derrick G-Code Programing 2 09-03-2007 09:44 PM
reversing a ac servo motor 69owb Servo Motors and Drives 9 09-02-2007 08:49 AM
BEMF and stepper motor reversing as a braking method? Oldmanandhistoy Stepper Motors and Drives 26 11-09-2006 12:37 PM
wiring reversing switch for a 220 v motor Runner4404spd General Electronics Discussion 2 11-01-2006 10:26 PM
