Old 08-28-2008, 10:09 AM
WEBBERS_14 is on a distinguished road
DYNAPATH 20, WHEN E-CODE IS ENTERED, POSITION DISPLAY DOES NOT UPDATE.
Hi everyone
I need some help with my machine. I have a Lagunamatic 310 with a dynapath Delta 20 controller. One the previos machine I ran, also had a delta 20, When I entered an E-code and executed the line, My position display would zero out to the new offset. My new machine doesnt. It takes E-code, and If I do a Move to 0,0 with the e-code active it goes to the programmed zero, but displays the coordinates from my machine reference position. any help would be greatly appreciated.
Kevin
Graphics display fadalman Fadal 2 06-23-2008 08:34 AM
RPM display fatal-exception Mach Mill 0 11-24-2007 03:02 PM
EZTrak DISPLAY dominicmarceau Bridgeport and Hardinge Mills 8 05-30-2007 10:18 AM
Toolpath display raytor Mach Mill 1 11-04-2006 08:54 AM
Position Display on fanuc 6m fredf1 Fanuc 1 10-22-2005 04:08 AM
