Old 08-27-2008, 12:44 PM
akschu is on a distinguished road
About to pull the trigger on a Grizzly G0602
Group,
I'm completely and absolutely lathe ignorant, but I'm wanting to guy a benchtop rig to cut small parts out of aluminum. Nothing very complex, mostly bushings, adapters, things like that.
I simply cannot afford the cost, shipping, and space of a larger lathe because I have a small shop, and finding a good deal on a used lathe is difficult because I live in Alaska where there aren't a bunch around. Because of these things I called Grizzly and was quoted $250 to ship the G0602 to my doorstep which is reasonable for a 440lb machine.
Now the questions:
1. I make it a rule to not buy cheap tools because they always break and then I'm stuck replacing them with what I should have bought the first time. Does this G0602 qualify as a cheap tool?
2. What kind of accuracy am I going to get out of this? I would like to cut my parts to .001". Is that possible with this lathe?
3. What kind of tools to I want to order with this lathe since I'm already going to eat a ton of shipping cost? I need to be able to cut bushings with a flange to start. I also need to cut out the inside of some round stock.
4. Is there a better deal on a different lathe I should be looking at?
5. Can this lathe be converted to CNC later? I certainly would like to do this in a year or two when I finish a few other projects.
Thanks for answering my questions.
schu
Old 08-27-2008, 01:16 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi akschu. Welcome to the Zone!
Make sure you specify the liftgate truck. And also make sure that an 18 wheel truck can GET to your doorstep.
I live on a narrow lane, and even though Grizzly and UPS freight assured me that a smaller truck would come, the 18 wheeler that showed up could not make the turn. I ended up scrambling to get a neighbor's help with a high lift tractor.
I think the 10 x 22 is the most bang for a buck lathe you can buy. There are several threads here about converting it to CNC.
CR.
Old 08-27-2008, 01:25 PM
Here are some links:
Grizzly G0602 10" x 22" Lathe Conversion
New Grizzly G0602 10x20 Lathe
CR.
Old 08-28-2008, 03:36 PM
michaelstranny is on a distinguished road
Grizzly
Hey askshu, I bought 9729 about 2 yrs ago. Burned up 3 motors when I first got it. They're tech. dept helped me over the phone and kept sending motors. They were polite and helpful even when I wasn't. I have a less than .001 tolerance x and y axis. I'm very happy with my machine. The single most helpful other tool I bought was an H7762 tool grinder. I bought most of my other tooling from them, probably more money than I spent on the machine.
New Grizzly G0602 10x20 Lathe twehr General Metal Working Machines 159 04-17-2012 06:50 AM
Grizzly G0602 10" x 22" Lathe Conversion derekbackus Vertical Mill, Lathe Project Log 133 10-30-2011 06:14 PM
pull studs najnielkp General Metal Working Machines 8 06-11-2009 08:42 PM
Need Help!- BAR PULL? travis1 Haas Lathes 10 02-11-2009 02:22 PM
Any opinions on the Grizzly g4016 lathe or other Grizzly lathes? DublD General Metal Working Machines 3 11-26-2006 12:23 PM
