Old 08-27-2008, 05:00 AM
Lugy is on a distinguished road
Tapping problem on Yang Eagle SMV1000
Firstly I hope this is the right place for it.........
Right we have a Yang Eagle SMV1000 running Accramatic 2100 control.
When we run a fixed tapping cycle (G84.1) the machine will first index the spindle and tap the hole as per usual, then reverse the spindle and come back out the hole. When it reaches the clear plane it will rotate the spindle 360 deg one way quickly then very slowly rotale back to where it was (0 degrees)
We have looked at the encoder belt and fitted a new one thinking this could be the cause. Any other ideas?
Old 09-10-2008, 02:44 AM
Anyone?
Jobs are taking twice as long to come off the machine.
Old 09-10-2008, 11:17 PM
DennisCNC's Avatar
DennisCNC is on a distinguished road
I think the control is loosing position so it rotates it slowly to find the index pulse? I dont have any experience with Accramatic controls just a general thought. Did you try moving the wire around a little see if something is loose?
Dennis
Fanuc OT/Yang Lathe memory problem? alikatcraig Fanuc 9 03-16-2012 06:20 PM
deep hole tapping problem ak_crabber General Metalwork Discussion 9 02-05-2009 05:44 PM
Having a problem using rigid tapping on my SL10.. locash Haas Lathes 9 05-22-2008 08:15 AM
Problem Tapping Stainless bobcor General Metal Working Machines 16 04-21-2008 02:35 PM
Rigid tapping problem GITRDUN Haas Mills 9 11-16-2006 07:27 AM
