Old 08-26-2008, 06:37 PM
clovenedhoof is on a distinguished road
slant bed lathe?
I'm a longtime reader of the forum but have rarely posted,
I'm designing a CNC gang tooled lathe, I'm using a XY table from a Taig mill for the cross slide, and 400 once/inches steppers for control. I'm using a Hardinge high speed head stock for it and 2x6 1/4" steel for the frame. The problem I've run in to is that my headstock is designed for the motor to be mounted underneath. The problem I face is that it if I place the motor under the lathe as is i'll end up with the lathe very tall, I was thinking about making the whole lathe a slant bed lathe. Basically mounting it at a 45 degree or so angle. Then I could mount the motor under the headstock and not have the lathe be too tall.
Here is a picture of my set-up so far.
http://s133.photobucket.com/albums/q...t=DSCF1244.jpg
the advantages I see are:
the coolent and chips will be easier to collect
the lathe wont' take up as much room on my bench.
does anyone else have any opinion?
-Chris
Old 08-27-2008, 02:04 AM
Guldberg is on a distinguished road
It would work. Just remember that your x-axis has to fight gravity when you slant it. Also the new height is determined buy the "height" of the x-axis (in a 45deg angle). It could end up higher than just putting the motor underneat. Have you considered putting the motor underneat the bench?
Build Thread- Slant bed CNC lathe from scratch Guldberg Vertical Mill, Lathe Project Log 394 11-24-2011 09:22 PM
Does someone know about Hardinge Super Slant Lathe? dadv2 General Metalwork Discussion 5 01-29-2009 12:15 PM
MAZAK Quick Slant 30N 4 Axis CNC Lathe ISHY General Metal Working Machines 2 08-24-2008 03:05 PM
Slant-bed lathe question zephyr9900 Mechanical Calculations/Engineering Design 18 09-07-2007 07:57 PM
What's the advantage of a slant bed lathe? Splint General Metal Working Machines 4 07-24-2007 09:59 PM
