Old 08-23-2008, 08:14 PM
josh591 is on a distinguished road
Sawing with a mill and other tooling?
I'm new to milling and was wondering if they make "saws" that can be mounted in a mill?
I would imagine it would be a saw blade attached to a shaft that would go into the mill. Then you could saw material in half that was clamped at two ends vertically.
I think "keyway cutters" are what they are called but am not sure. They seem to make cutters to cut groves using a vertical mill.
Also, is there a website or book that tells you what tools are used for what?
From my limited experience, I've figured out I can use flat end mills for just about everything from cutting surfaces to edges. Drills/taps are obvious. Ball end mills for putting radius on things.
Thanks in advance!
Old 08-24-2008, 07:33 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
It's called a slitting saw and arbor--available from many sources--Here's one:
http://grizzly.com/products/searchre...slitting%20saw
http://grizzly.com/products/searchre...litting%20saws
CR.
Old 08-24-2008, 07:39 AM
Here are a couple of the best online guides:
http://www.americanmachinetools.com/...ng_machine.htm
http://www.americanmachinetools.com/...se_a_lathe.htm
CR.
CNC Knee mill and some tooling for $10k can it be done? M4RK_23 Knee Vertical Mills 18 02-19-2008 05:51 AM
Sawing All of the Bar Stock stang5197 General Metalwork Discussion 4 11-27-2007 08:44 AM
Precision sawing Kernersville North Carolina schiada96 Employment Opportunity 0 06-07-2007 01:02 PM
Advice requested on getting first mill tooling.. hotponyshoes General Metalwork Discussion 9 04-04-2007 10:48 AM
Mill Tooling Question kochevnik General Metalwork Discussion 7 01-11-2007 11:40 AM
