Old 08-22-2008, 09:59 AM
Cadtech2000 is on a distinguished road
Question Large vert Bandsaw table feed data
We are presently rebuilding / modifying a Pehaka SF-8 bandsaw made by: Petzing & Hartmann Maschinenfabrik GmbH & Co.
We've had to remove the ball screw drive motor (it was working at 3-5% of its range and thus wasn't adjustable).
I'm presently looking at replacing this drive with one more suited for the application, we are also going to control this drive's torque depending on the material, cross-section and size of what is being cut.
Does anyone have information as to general feed forces, feed speed depending on blade type, material, and area?
we are using a Hakansson blade M42 4-6 1 x .065 (trying to figure out the exact model).
Most materials cut are ~H11 ~H13 (hardenned and annealed) mostly round and square (up to 650mm diameter).
Thanks,
Tags
bandsaw, blade, feed, force, speed
My Solsylva CNC Large Table 50% completed Wineryrjd DIY-CNC Router Table Machines 0 01-25-2007 06:24 PM
DIY CNC Router Steele Large Table Wineryrjd DIY-CNC Router Table Machines 1 11-30-2006 07:16 PM
Speed feed data link to cutter and material camtd EdgeCam 2 10-20-2006 12:20 AM
Where's the Lathe Speed, Feed, and Depth Data?? Otokoyama General Metal Working Machines 4 02-06-2006 01:14 PM
